Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Interior Decorating
Old 10-06-2009, 01:37 PM   #1
Default Issues with hanging curtain rod
I'm attempting to hang a curtain rod over my bedroom window in my condo, but I'm running into troubles. It seems that when I drill holes in the dry wall, I am hitting the outer wall of my building, and it sounds like either a metal plate or concrete. This is causing the holes to be too shallow for the mounting screws.
Any suggestions?
Thank you in advance.
Rwd00 is offline   Reply With Quote
Old 10-07-2009, 01:28 PM   #2
Your walls should be at least 4" or so thick after you get through the drywall so it is unlikely you are hitting an external wall. It sounds to me like you might be hitting metal studs or other such framing components.
sdsester is offline   Reply With Quote
Old 10-07-2009, 02:39 PM   #3
Thanks for the reply. I think we've determined that it is the window frame. Any suggestions on how to punch through it?
Old 10-07-2009, 04:20 PM   #4
A good quality, sharp, carbide drill bit should do the trick for you. Be careful to use one the correct size because you will not be able to get any sort of screw anchor to work in metal. You may want to switch out the screws sent with the drapery hardware too as they were probably intended to go into wood or a screw anchor and not metal.
Old 10-07-2009, 06:16 PM   #5
Thank you. So you are saying not to use an anchor at all? And if I don't use the screws provided with the curtain rod, what sort of screws should I use?
Thanks again.
Old 10-07-2009, 07:12 PM   #6
An anchor will only work in the drywall and depending on how heavy your window treatments this may not be enough to hold the hardware in place since you will only get 1/2" or so of holding power. The anchor is probably not going to go all the way in to start with as the metal window frame will block it---it will not expand properly to bite into the drywall.
You would not be the first if you were to force a long drywall screw but I would think about a self-tapping metal screw. You will want to anchor into the window frame an inch or so so you will need an overall length of at least 1.5" to do this by the time you factor in the drywall thickness. Hopefully you have a real hardware store near where you can buy only the number you need. Drill your holes the diameter recommended for the screws you find.
Old 10-07-2009, 08:29 PM   #7
Ok, so basically drill through the dry wall and the window frame with the proper size carbide drill bit, and use a self-tapping screw without an anchor. The curtain set came with self-tapping mounting screws I believe.
Thanks again!
Old 10-07-2009, 08:43 PM   #8
Post
To the best of my knowledge, a Carbide bit goes into Concrete. For metal, you have to use a high-speed Steel bit. And Self-Tapping Screws. But the metal that the OP is encountering, could, sometimes be a brace for the Fire Escape or to anchor a Porch of the floor above. Also, it's best (for a Semi-Pro, at least) not to use the original screws or anchors in the package. Whether it's a curtain rod or a smoke detector! (No matter what)Don't Drink and Drive, Ever!!!
spark plug is offline   Reply With Quote
Old 10-07-2009, 09:36 PM   #9
You are thinking of a carbide or carbide tipped masonry bit? Twist drills also come in carbide. They are harder than regular steel bits.
Your advice not to use the screws that come with anything is great!
Old 10-07-2009, 10:34 PM   #10
Thumbs up
Thank you. And thank You for the correction. The fact is that the screws and anchors that come in the package (any package) are not meant for professional installation. Eliminate confusion through Education;Don't Drink and Drive, Ever!!!
Old 10-09-2009, 08:51 PM   #11
Is it possible that you are hitting the strapping? See pic for reference.
JRiegler is offline   Reply With Quote
Old 10-16-2009, 05:55 PM   #12
No it was actually the window frame. I just had to move the brackets 6 inches to left or right to avoid it. For the middle bracket however, I just used a shorter screw, and cut the plastic anchors to fit.
Thanks for the suggestions.
More On This Topic
Hello my name is Denise Robinson and on behalf of Expert Village I'm here to talk about how to decorate a cozy corner in your home. Next step we are going to do is putting a window treatment together I'm going to use plum color velvet curtains. As you... Read More »
Back in our room and now we've got our California closet system installed, we have one panel that's not painted, that we didn't have a backer board put on, so we can put the wall color behind it, in front of this will be the TV, which is, I think forty... Read More »
Imagine the compliments you will receive when people see your curtains in a fabric that complements your room's design. Imagine the surprise that will come when you share that your new curtains are made from tablecloth. Tablecloth curtains in a rich... Read More »
Hello! This is Atiya and on behalf of Expert Village I'm going to demonstrate on how to hang a curtain. First thread the curtain through the rod. Then get a sturdy chair so you could reach your window. Put the curtain in place and attach to the hook... Read More »
Hi I'm Denise Robinson and on behalf of Expert Village I'm here to talk about the loft. How to take a space a large space and divide it up into small living quarters. Okay the first step we're going to do is in putting our living room area together for a... Read More »
Tub leaking past shower curtain Outbacker Plumbing 6 11-07-2009 09:18 AM
Help - hanging curtain rods in drywall ontheDB General Discussion 8 10-10-2009 11:54 AM
hanging Mirir on door txmike Carpentry 9 08-02-2009 11:01 AM
Remove Load Bearing Wall Beneath Hanging Beam cnaildrivenail Remodeling 0 04-29-2008 01:06 PM
Hanging a Heavy Mirror frapha1 Site Help and Suggestions 4 07-29-2007 12:12 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
