Installing Set Of Coat Hooks In Drywall W/ Steel Studs - Interior Decorating - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Interior Decorating
Old 03-23-2013, 05:09 PM   #1
Installing set of coat hooks in drywall w/ steel studs
I'm installing a set of coat hooks (cedar wood) into drywall with steel studs. Do I need to drill directly into the metal studs in order to support the weight of the coats? The package came with drywall anchors, not sure if that's a good idea.
ronswanson234 is offline   Reply With Quote
Old 03-23-2013, 05:14 PM   #2
Rewards Points: 13,446
If it came with anchors there going to be some cheap ones.
A coat rack has to hold a lot of weight. With outwood studs I'm not seeing a great outcome on this one.
May want to concider dry wall adhesive on the back side and fine thread sheetock screws in the studs.
Tags
coat hooks , drywall anchors , metal studs
How to add blocking w/ steel or metal studs bergerdude Building & Construction 12 04-30-2013 09:59 AM
Anchoring to steel studs JPrachnick Building & Construction 5 11-19-2010 08:05 PM
Drywall Corner and Ceiling Skim Coat Rbchound Drywall & Plaster 6 04-29-2010 10:59 AM
ENT in steel studs? krazni Electrical 4 01-15-2009 01:04 AM
Steel Studs ? Steve Carpentry 3 11-24-2006 05:10 AM
