Installing Laminate Flooring ? - Interior Decorating - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Interior Decorating
Old 03-12-2013, 07:33 PM   #1
Rewards Points: 31
installing laminate flooring ?
NEED HELP,Looking for info. on installing laminate flooring, only problem is that ,it is for a bedroom approx.12X14, there is a High spot in one corner of the room I know that the wall has a chimmney behind it , this may be the cause of the rise in the floor, this would make the floor unlevel, any suggestions on making it level would help thanks
jjchips is offline   Reply With Quote
Old 03-12-2013, 08:19 PM   #2
DIY staff
Rewards Points: 7,174
There are many ways to do that---vinyl patching cement---self leveling compound---even layering roofing shingles can be done----take a 6 foot long straight edge and see how much gap you have in the low spot---
Old 03-12-2013, 10:01 PM   #3
Rewards Points: 13,266
Or going under the floor and figuring out what really causing the problum and fixing that as a permenent fix.
laminate flooring over laminate flooring bowbender6 Flooring 6 07-04-2012 10:27 PM
Installing laminate flooring ? ants1929 Flooring 10 02-24-2011 11:46 PM
Laminate flooring and such for kitchen christineka Flooring 5 01-04-2011 08:08 AM
installing laminate flooring garwoode Flooring 12 10-29-2008 10:21 AM
laminate v. hardwood flooring JDuc Flooring 11 01-13-2008 10:01 AM
