Installing Backsplashes, Issues With Electrick Switches/boxes? - Interior Decorating - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Interior Decorating
Old 01-16-2011, 02:42 PM   #1
Installing Backsplashes, Issues with electrick switches/boxes?
i am installing Backsplash tiles between kitchen counters and cabniets.
It looks after installing tiles, Electrical boxes will not be level and don't know how front plate will install. Please advie what is common practice in this case. It looks metal boxes are fixed as I can't drag it out easily. Any solution to move those boxes up to new tile level?
port80 is offline   Reply With Quote
Old 01-16-2011, 05:21 PM   #2
A Little Of Everything
Rewards Points: 1,356
They make little extenders for just such a problem.
http://www.amazon.com/Electrical-Box...8050703&sr=8-4
DrHicks is offline   Reply With Quote
Old 01-16-2011, 05:49 PM   #3
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
as long as the boxes are not so unlevel you cannot utilize the adjustment on the device to level it, you are fine. The trim plates attach to the device, not the box, unless they are blank covers. Then you simply get a blank cover with a bracket that allows for adjustment.
and to make up for the depth, as the other poster stated, extensions. I prefer the non-metallic ones (plastic).
installing a new window/vinyl siding issues wengang1 Building & Construction 2 10-14-2010 10:41 AM
Issues After Installing Light Switch shriekback Electrical 11 09-07-2010 11:47 AM
Installing a one piece shower... plumbing issues singforsupper Plumbing 2 06-01-2005 09:26 AM
