Ideas For A Home Office Ceiling? - Interior Decorating - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Interior Decorating
Old 01-25-2012, 08:15 PM   #1
Lavid2002's Avatar
Rewards Points: 85
Ideas for a home office ceiling?
I am renovating a home office that is about 13' by 11'
I just tore out a drop ceiling with the standard white tiles. I want the office to be full of dark woods. I was looking into the option of installing tongue and groove boards on the ceiling, but after looking at some materials I don't know how good that would work out.
Any ideas for a ceiling? Thanks guys!
Also, if you have anything else you would like to see in a home office, post some pictures!
-Dave
Lavid2002 is offline   Reply With Quote
Old 01-26-2012, 06:55 AM   #2
Rewards Points: 327
Are you planning to do tongue and groove planking on
the walls and the ceiling as well?
Have you considered just sheetrocking the ceiling? How many windows
in this room?
We have a cedar tongue and groove ceiling in a bathroom, as well as on the walls.
It also has a lot of mirrors in this bathroom, so it brightens up
the room. I'll show you a pic if that's what you want.
When you say dark, do you mean dark walls as well?
If your ceiling is in bad shape, you can sheetrock right on top of the
existing ceiling.
Two Knots is offline   Reply With Quote
Old 01-26-2012, 08:47 AM   #3
Lavid2002's Avatar
Rewards Points: 85
in this room?
existing ceiling.
It is in a basement, it used to be a bedroom. I am taking the closet out and opening the room up. The room is only 8' tall.
The ceiling is out, the only thing left over head are the joists. I could put sheetrock up, but I would like to go with something a little more elegant. Something that shows worksmanship.
Pictures would be great!
Ill post some tonight too.
-Dave
Old 01-26-2012, 09:02 AM   #4
Jack of all - master none
hyunelan2's Avatar
Rewards Points: 692
You could do a coffered ceiling, an infinite amount of options for wood or drywall and molding in these:
hyunelan2 is offline   Reply With Quote
Old 01-26-2012, 10:27 AM   #5
Too Short? Cut it Again!
Tin ceilings? Polystyrene replicas? They come in many forms. This is just one supplier.
http://www.americantinceilings.com/p...FQGd7QodNBCC6Q
Here is an extensive gallery of some ceiling ideas:
http://talissadecor.com/gallery.html
Here is one good source for all kinds of molding:
http://www.wishihadthat.com/crown-mo...FdBrKgodsgehMg
Old 01-26-2012, 11:43 AM   #6
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,086
80% of our house is paneled. They covered the seams on the kitchen ceiling with faux beams. You could do this with beadboard paneling giving a similar look to tongue and groove but a lot easier and cheaper.
I still wouldn't recommend this though, unless you plan on painting it white. The dark ceiling makes the kitchen incredibly dark. Even in the daytime, we usually have all the lights on to do anything.
Be careful of too much "dark" or you may turn your basement office into a cave.
Old 01-26-2012, 12:23 PM   #7
Lavid2002's Avatar
Rewards Points: 85
I REALLY like the look of these two! I think we have a winner Let me snap some pictures of the basement.
-Dave
Old 01-26-2012, 03:05 PM   #8
Lavid2002's Avatar
Rewards Points: 85
Also, whoever drywalled this basement when we moved in about a decade ago, just built a sheetrock box to cover this plumbing. To me that's the definition of lazy. I would like to move some of this plumbing up in between the joists so it is out of the way.
Old 01-26-2012, 04:10 PM   #9
hyunelan2's Avatar
Rewards Points: 692
You can only drill holes so big in joists. You can probably get that copper moved up through the joist, but I'm not sure about that drain pipe. How big are those joists, and what size is that drain pipe?
Old 01-26-2012, 04:53 PM   #10
Lavid2002's Avatar
Rewards Points: 85
I would like to find someway to tuck it up neatly, eve if it means I cut it at the top of the pipe, turn it so it goes inwards (Away from the camera) and then below the joist once it is past the drywall and I can still have a neat looking ceiling and wall set up.
How's that for a plan? And we'll tuck the copper pipe.
I will measure them soon.
Old 06-03-2012, 11:54 PM   #11
Lavid2002's Avatar
Rewards Points: 85
Making my run through the forum and letting everyone know what I ended up doing. Here it is 80% complete. Thanks for the inspiration!
Plaster ceiling with peeling paint annaem Painting 14 01-19-2012 12:10 PM
Mobile Home Stomped Ceiling shick Painting 2 08-10-2011 05:46 AM
Installing Ceiling Speakers in Pre-wired Home heywazzupdude Home Theater 2 12-27-2010 10:12 AM
Building is settling...wall separating from ceiling...need ideas! Wolfies167 General DIY Discussions 5 09-29-2009 11:22 PM
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 10:48 AM
