I Need Help With A Design Layout - Interior Decorating - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Interior Decorating
Old 08-17-2011, 12:26 PM   #1
I need help with a design layout
I'm redecorationg my apratment, and I'm looking to make all the rooms flow but at the same time appear as separate rooms.
My inspiration is: Modern, Elegant, Colorful and Damsk & Animal print patterns.
I have ideas here and ther for what I want it to look like but I can't seem to really get the damask and animal print to meld well (these both will be in all rooms)
Any ideas? (images would help)
angelleeca is offline   Reply With Quote
Old 08-17-2011, 03:07 PM   #2
m1951mm's Avatar
Damasks and animal prints will work beautifully together as long as you are in the same color palete. Searching for fabrics is a difficult and time consuming process. You first need to know your budget. The higher end you go the more choices you will have. Doing those type of patterns are much more difficult in low end fabrics. Are you in an area that has large shopping (like a decorator outlet)? Maybe just take a trip to your local fabric store see if there is something there you like and ask a sales clerk if they know someone in the area who does sewing on the side.
Give me an idea if you are wanting this for a long time and are willing to spend some $$$$$ for fabrics or if you want to do this, or the best you can on a smaller budget. That will help me guide you to resources.
Just doing an internet search on fabrics, be it drapery quality or upholstery will give you an idea what you might be looking at spending per yard on your fabrics. Then you will have fabrication costs, someone who sews it up for you unless you do that yourself. If you are looking to do ready made, I probably would not be able to give you any better ideas than to look at say J.C. Penneys, Target etc. to try and find your wishes.
m1951mm is offline   Reply With Quote
Bathroom DWV Layout Problems grymes56 Plumbing 8 05-15-2011 10:00 AM
Help me design a closet (picture of room layout included) DannyUpper90 Remodeling 6 01-07-2011 12:29 PM
How To Check A Steel Carport Design abrogard Building & Construction 8 10-05-2010 04:59 AM
General HVAC Design Issue Robert Green HVAC 4 05-29-2010 12:02 PM
Laminate wood floor layout questions nathan.tran Flooring 4 08-30-2008 11:56 PM
