How Should I Set Up/paint This Room? - Interior Decorating - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Interior Decorating
Old 07-28-2013, 11:53 AM   #1
How should I set up/paint this room?
I just bought this house, and we will be using this as a family room. I have a large red sectional, and that is about it. Any ideas?
Kristen0914 is offline   Reply With Quote
Old 07-28-2013, 03:09 PM   #2
Hard to say about the set up because we only have two angles of the room, but, I would say, put your sectional under the two windows, and as for paint, I would do a soft grey because it would make your couch really pop (one has to assume that when buying a red couch, it is intended to be a focal area in the room ). I am also really big on flowy white curtains at the moment, so I would ditch the pull across blinds and opt for some nice white wood ones with the flowy white curtains...
Rkn is offline   Reply With Quote
Old 07-28-2013, 06:49 PM   #3
Too Short? Cut it Again!
Well, that wallpaper border has to go. In addition to being dated it is at a really weird height.
Can you do a floorplan? I use Sweet Home 3D---free open source software with low learning curve---but even a sketch would give us a feel for the room. And what are the dimension of the sofa. Anything else that is earmarked to go in the room?
No biggy for this but you might want to update your profile with general geographic location at some point. Given the palm trees, I am guessing Florida?
Insulating a cold/well room? Lynch Building & Construction 23 07-25-2014 02:49 PM
converting a great room into upper and lower room denemante Building & Construction 7 10-18-2012 06:44 PM
Need a foundation in my laundry room sweetfarm Building & Construction 14 09-06-2012 09:49 PM
Bathroom to Laundry Room to Bathroom bcatanz10 Remodeling 2 10-10-2011 09:45 PM
Vapor Barrier on elevated 4 season room Indyc0lt Insulation 3 09-15-2011 01:41 PM
