Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Interior Decorating
Old 07-15-2009, 03:55 PM   #1
Default how to make T & G less....well.... T & G
We just bought a house. I absolutely love it! There is 1 thing I hate about it: it is 100% tongue and groove! All of my inherited, antique furniture looks very out of place (or like the wood fairy puked everywhere) , not to mention I'm not the biggest fan of tongue and groove. I don't mind one room in it, or t & g ceiling, but EVERY wall & ceiling are covered in it (4 beds, 2 baths, livingroom, kitchen, diningroom, hallways, closets, etc.... )
We will take it down wall by wall, as I get sick of it. But, does anyone have any clever disguises that would help so that I don't get overwhelmed when we move in.
Thanks!
okjohnson is offline   Reply With Quote
Old 07-15-2009, 09:35 PM   #2
General Contractor
I wouldn't waste my time tearing it down unless you plan to salvage it. Just sheetrock over it when your ready, that's a lot less work. Sorry I don't have any ideas for disguising it that would be more cost effective then rocking it.
ARI001 is offline   Reply With Quote
Old 10-16-2009, 10:57 AM   #3
Is it dark wood? If so you could try painting over it in a pale shade to make it less obvious.
Before you take it down, you really need to find out why it's there in the first place. I guess it's because the walls aren't in great condition and the previous owner put it up there to hide the fact.
Try and take a piece down in a really inconspicuous place first and then you can gauge what the rest of the walls are like.
Hope that helps.
Alexandra Toso
Last edited by AtlanticWBConst.; 10-16-2009 at 02:59 PM. Reason: SITE RULES VIOLATION: Advertising Link Removed
alexandratoso is offline   Reply With Quote
Old 10-16-2009, 11:50 AM   #4
Licensed Builder
Handyservices's Avatar
Yep, I completely agree with ARI on this one. Too much unnecessary work with removalof existing T&G. If you have a smooth surface to work with, then sheetrock it.
Darwin.
Handyservices is offline   Reply With Quote
Old 10-16-2009, 05:43 PM   #5
One problem with drywalling over it is all your electrical boxes are going to be tucked in too deep. If you fill the grooves with compound and sand, then apply this it might work out for you. I use quite a bit of this material and really like it but admit I have never tried it on a T&G situation so am just passing on what the instructions suggest. It is not hard to use but it might be nice to have an extra person until you get used to the process.
http://www.spec-chem.com/nuwal/index.htm
sdsester is offline   Reply With Quote
Old 10-22-2009, 10:05 AM   #6
Newb
NewImage's Avatar
Just paint over it...
NewImage is offline   Reply With Quote
Old 10-22-2009, 11:10 AM   #7
General Contractor
That's what these are for:
http://www.lowes.com/lowes/lkn?actio...CRD&lpage=none
Old 10-24-2009, 09:40 AM   #8
I had one wall of T&G that drove me mad, so I can empathize with a you having a whole house of it! Yikes!
I dry walled over mine, first adding sheet insulation as the wall felt cold. (I found there was NO insulation on that wall.)
Another benefit to leaving the T&G in place -- you always have a solid place to hang any artwork!
roxksears is offline   Reply With Quote
Old 10-26-2009, 04:14 PM   #9
Newb
NewImage's Avatar
Guess you guys would really hate my living room....
More On This Topic
If you have the need to store large amounts of ice, building an ice house is a project for you. Popular many years ago, now most freezers now come equipped with ice makers to produce a sufficient amount of ice for a family, but are not designed to handle... Read More »
How to Hang a Fan
How to Hang a Fan by eHow.com
Ceiling fans are a way to help cool a room during the summer and circulate warm air during the winter. They're available in many styles and with numerous lighting options to match the decor of any room. There's no need to hire an electrician to hang a... Read More »
Home radiators are an excellent heat source and are used around the world. Radiators are usually located against walls and near stairways and resemble large twisting pipes. These pipes carry the water or oil that is heated to provide a source of warmth... Read More »
When your displaying your clocks there's a number of ways that you can do this you can put them on shelves like this I like to layer everything as you can see, it comes out from the wall and I've used the surface of this pretty well. I got 3 different... Read More »
Painters cut in a ceiling by painting around the outer perimeter of ceiling, where it meets the wall. Cut in the ceiling with a paintbrush before you paint the entire ceiling with a roller so your finished painted room looks neat and free of unsightly... Read More »
FREE plans/instructions for easy to make Magic Box! DangerMouse General Discussion 5 07-23-2009 06:14 PM
Want to make cuts in cabinet walls to put in shelfs humberguy Carpentry 3 07-09-2009 11:07 PM
how to make white mortar for brick wall nhertel Building & Construction 2 05-26-2009 10:22 AM
Need to make bases for porch columns rafaell General Discussion 3 09-01-2008 11:32 PM
Anyone know how to make cafe doors? versatile1 Carpentry 3 08-01-2008 11:39 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
