How To Hide Raditor Pipe Gaps? - Interior Decorating - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Interior Decorating
Old 11-01-2013, 08:59 AM   #1
Rewards Points: 14
how to hide raditor pipe gaps?
these are the radiator pipes going from my 1st floor to 2nd floor. what can i do to cover the gaps in the drywall ceiling? this picture is actually not bad... but other rooms look much worse
tung256 is offline   Reply With Quote
Old 11-01-2013, 09:15 AM   #2
Rewards Points: 13,732
Clean up around them and use paintable caulking.
Old 11-01-2013, 09:16 AM   #3
Rewards Points: 165
You could check at your local hardware store or big box store for a pipe collar. They are the same thing that most people have on the pipes coming out of the walls under their sinks. They do make hinged ones that are used for when you can't just slip one over the open end of a pipe.
chronojosh is online now   Reply With Quote
The Following 2 Users Say Thank You to chronojosh For This Useful Post:
Startingover (11-01-2013), tung256 (11-01-2013)
Old 11-01-2013, 09:18 AM   #4
Rewards Points: 165
That's a shot of the one for my toilet supply line. Although it's not a hinged one, I think you get the idea.
Old 11-01-2013, 09:42 AM   #5
Rewards Points: 14
ahhh, i did not know a hinged one exists! will run out to home depot now. thanks!
joe, i cannot use caulk because some of the gaps are huge
Old 11-01-2013, 09:44 AM   #6
PoleCat's Avatar
Rewards Points: 1,646
Here is one of the nicer looking ones.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
The Following User Says Thank You to PoleCat For This Useful Post:
Old 11-01-2013, 09:55 AM   #7
K&B Designer
Live_Oak's Avatar
Maybe hire a plumber to do a more professional job? Or enclose the pipes into a chase to hide the pipes entirely?
Do it right from the beginning if you only want to do the job once. It'll be cheaper in the long term.
Live_Oak is offline   Reply With Quote
expanding foam for gaps in masonry foundation LMHmedchem Concrete, Stone & Masonry 6 08-22-2012 09:36 PM
Line spacer gaps in concrete driveway and sidewalks - ok to fill up gap? daluu Concrete, Stone & Masonry 3 07-25-2012 10:20 PM
Basement Window / Buck Gaps and Leaks ? Carles Windows and Doors 2 07-01-2012 12:06 PM
Dark over light...Do I need tinted primer? melissaandkris Painting 17 09-09-2011 10:43 AM
Purpose of gaps between sheets of plywood? diy888 Tiling, ceramics, marble 35 02-16-2009 11:01 AM
