Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Interior Decorating
Old 06-23-2009, 03:45 PM   #1
How to cover a fireplace
Hi, I recently moved into an apartment and my wife really doesn't like the fireplace. (Here are pictures of it. http://www.flickr.com/photos/9013321...7620269988413/)
Our landlord won't let us paint it, so my wife wants to cover it with this embossed wallpaper that kind of looks like a tin roof. We would then paint the wallpaper
I bought some mdf to cover the fireplace frame, but I'm stuck at how to affix the mdf in a non-permanent way. Any ideas? Is this the right forum?
smmsanders is offline   Reply With Quote
Old 06-23-2009, 03:50 PM   #2
Xtreme DIY'r
Are you going to be using this fireplace?
You can't put wood/paper within a certain distance
I'm not even sure you can do it Temp even if you won't use the fireplace ?
Old 06-23-2009, 03:57 PM   #3
Yes, it's a non-working fireplace.
Last edited by smmsanders; 06-23-2009 at 04:03 PM. Reason: same post as later post
Old 06-23-2009, 04:00 PM   #4
It's a non-working fireplace, or at least, I can't use it as stipulated in the terms of my lease. I also put a flue damper in it so I won't loose cool air in the summer and hot air in the winter. I think it used to be a coal stove fireplace, but like so many old apartments, the stove was taken out.
Re wood, the mantle that is already on the fireplace is wood and I've actually seen a lot of decorative/old coal stove fireplaces made out of wood in old apartments in my neighborhood.
Old 06-24-2009, 02:47 AM   #5
Wow!! i love your wife's choice. The wall papers looks really elegant and chic. As long as it is a non working fireplace you can paste wallpaper.
Dana
Dana11 is offline   Reply With Quote
Old 06-24-2009, 09:12 AM   #6
Thanks, she would appreciate the compliment.
Once you paste the wallpaper, is it easy to take off? The fireplace also has these pegs that stick out of the wall. I didn't want the wallpaper to look uneven.
Old 06-24-2009, 09:34 AM   #7
the Musigician
DangerMouse's Avatar
i'm with dana, that's nice textured paper.
i wonder if you could use it on ceilings to imitate the tin tile style too? paint it, then antique it?
nice choice!
DM
[SIGPIC][/SIGPIC]Click
to see some of my original magic tricks and trick boxes!
New project: removal of old fireplace-replace with a new fireplace! MrShadetree0222 Building & Construction 14 10-16-2008 07:12 PM
temper glass for fireplace mantel shelf sil Interior Decorating 3 02-13-2008 09:10 PM
Fascia cover filled with water/ice causing leaks brianbh Roofing 10 02-11-2008 08:34 PM
Possible to build direct-vent fireplace? DIYerself General Discussion 3 12-22-2007 11:07 PM
