Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Interior Decorating
Old 03-01-2009, 05:36 PM   #1
How can I cover up this closet?
I'm looking for an economical way to cover up this closet. Ive thought about putting up curtains but wonder if that's the best way to go.
Any suggestions would be greatly appreciated (under $50 would be nice. too...).
Thanks...
acyate is offline   Reply With Quote
Old 03-01-2009, 06:17 PM   #2
Xtreme DIY'r
I use sliding doors, HD has some inexpensive ones
The ones I bought are mirrored doors
Pretty sure they are over $50
Fabric/curtains might be all you can do under $50
Old 03-02-2009, 09:13 AM   #3
In the picture it looks like you have accordian-style doors. You can use a spray adhesive to attach fabric to the front of the doors. You'd want to lay each door on the floor to make it easier.
Otherwise, check local salvage yards, yard sales and Craigslist.
gma2rjc is offline   Reply With Quote
Old 03-02-2009, 10:09 AM   #4
the Musigician
DangerMouse's Avatar
best bet IMHO is find your nearest Habitat for Humanity ReStore and look for bi-fold doors in decent shape and paint them to match decor. doors there are normally 5 and 10 dollars from what i've seen and purchased. tracks may be extra, but it LOOKS like you may already have an old track up there, yes? hard to tell from pic.
DM
[SIGPIC][/SIGPIC]Click
to see some of my original magic tricks and trick boxes!
Old 03-08-2009, 04:16 AM   #5
Hi there!
by looking at the picture i got an idea that instead of hiding your closet why do you put some nice wooden paneled sliding door to it OR you can also try frosted sketched sliding doors for the closet giving it an arty touch instead of feeling bad about it.
Dana
http://www.ninaathome.com
Dana11 is offline   Reply With Quote
Old 03-08-2009, 08:55 AM   #6
STAFF
BigJim's Avatar
A little more than $50 but maybe a bookcase insert?
BigJim is offline   Reply With Quote
Old 03-08-2009, 04:39 PM   #7
Drywall contractor
"Cover up" could be interpreted a lot of different ways. A few 2"x4"'s, a couple of sheets of drywall, some joint compound.........just kidding. Under $50.00 doesn't leave many options other than the curtains you already thought of. New bi-folds would be my suggestion, but out of the $50.00 budget.
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 03-08-2009, 06:01 PM   #8
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Bi-Fold Doors may be the trick. Cost would be a little more than $50.00, but would look nice. Measure out the opening and see if you can find a good deal on door sets that will fit the space.
Example below. In your case, look for MDF, or other inexpensive style door, and omit the installation of wood casings.
Before:
After:
- Build Well -
Central Air Outside Unit Cover czars HVAC 2 01-07-2009 11:23 PM
Hardwood closet threshold question DIY-Renovator Flooring 1 07-27-2008 05:42 AM
Fascia cover filled with water/ice causing leaks brianbh Roofing 10 02-11-2008 08:34 PM
Musty smell from closet after leak Musty General Discussion 2 09-10-2007 09:36 PM
Want to build closet in attic. Need advise. mbrittb00 Building & Construction 1 11-14-2006 07:58 PM
