How Bright Should Living Room Fixtures Be? - Interior Decorating - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Interior Decorating
Old 12-16-2013, 04:01 PM   #1
I'm working on a project to add light to my living room and am hoping for some advice. My most fundamental question is how many bulbs to add. In reading this HGTV article, it sounds like ambient light levels should be no more than 3,000 lumens. However, since lumens are "lost" when light bounces off the walls and ceilings. Any thoughts on what that loss would be, and therefore how bright to make the bulbs?
(FYI, I'm planning on building low profile valance-style fixtures to provide indirect light off the ceiling. These would be horizontal fixtures along the wall. 1" below the ceiling that could be 18' on one side of the living room and 8' on the other. I've attached some pictures (which are easiest to see in gallery view) and happy to sketch out the overall plan, such as it is. I'm planning on using low-voltage "flat wire" that is nearly invisible when painted over.)
Thanks again for the guidance!
Last edited by procon; 12-16-2013 at 04:13 PM. Reason: added clarifying information
procon is offline   Reply With Quote
Old 12-16-2013, 05:42 PM   #2
Rewards Points: 6,652
Forget everything you have read, watched or heard on HGTV. Around 530 Lux is usually what it is where I sit at. The bulb is a 12/22/33w 6500k cfl, that I normally have at the 22 watt level.
The colors on our Panasonic Plasma, which has been calibrated, looks better with the 6500k lighting. All bulbs in our house are 6500k cfl.
Old 12-17-2013, 02:42 PM   #3
Greg,
So, it sounds like you may be using about 1,200 lumens of light. I'll use that as a starting point, thanks.
It sounds like I could estimate how many lumens I need to get to ~530 lux based on the living room's sq. footage, but it may also be easier to just install the bigger one first and see what I'm missing. If the room is too dark, I can move the transformer over to the smaller one and just add more lights and a larger transformer to the bigger one.
Thanks again for the guidance.
Old 12-17-2013, 03:31 PM   #4
My living room is approx. 14x16, with a dark Red color on the walls, with a White ceiling. With the lighting and wall color, it actually works out very well for watching movies and TV on our Plasma.
Old 12-21-2013, 01:51 PM   #5
use CFL or LED
Living room is the main room where we spend our leisure time. Living room light should be CFL or LED . CFLs trend offer good light coverage. LEDs are great for more decorational light.
mondaywest is offline   Reply With Quote
Old 12-22-2013, 01:12 PM   #6
Rewards Points: 274
I agree with this guy.
alexjoe is offline   Reply With Quote
problem with transition from living room to kitchen tpiro Flooring 1 11-01-2012 09:14 PM
Complicated Living Room kwood4444 Interior Decorating 20 05-17-2012 10:12 PM
Living room arrangement challenge... r3yrey Interior Decorating 5 05-16-2011 02:22 AM
trailer in my living room (must read) wengang1 Remodeling 0 01-19-2010 04:30 PM
Choosing colors for painting living room, kitchen Bugpals Painting 2 05-15-2009 10:19 AM
