How To Attach Cornice Boards To The Wall - Interior Decorating - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Interior Decorating
Old 10-26-2008, 05:07 PM   #1
Molster
How to attach cornice boards to the wall
Hello,
I was wondering if there was anyone out there that has a good plan for attaching the "L" brackets to the cornice board and to the wall?
Thanks in advance.
molster is offline   Reply With Quote
Old 10-28-2008, 12:43 PM   #2
kimberland30's Avatar
When we hung our cornice boards, the L brackets were at the very top and very bottom of the side panels, so it was easy to get a drill bit in there. We used a drill bit extender. DH also has a flexible drill bit extender that can bend but we didn't use that because we didn't need to.
Good luck! We put up 5 cornice boards - including one over our slider - and it was a PITA.
kimberland30 is offline   Reply With Quote
Old 10-29-2008, 06:21 AM   #3
Molster
Cornice board
Thank you. That just confirms the way I was going to do it. What's the depth of your cornice board(away from the wall,) 4" or 6"? I also had another idea as well. I could attach the L-brackets first to the wall then hold the cornice board up and screw into the cornice board, then my hand could fit up into the cornice.
Thank again for you help.
How to diagnose problems with wall kahlan General DIY Discussions 5 10-22-2008 10:18 AM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 05:08 PM
Recommended way to attach firring strips to Drylock wall? jbwaechter Building & Construction 1 04-29-2007 05:08 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
