Hooks In A Closet - Interior Decorating - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Interior Decorating
Old 11-18-2013, 01:13 PM   #1
Rewards Points: 175
Hooks in a closet
OK, file this under uber anal, but I was going to install hooks in a closet, and as I was marking the halfway point between the closet rod and the front wall, I thought "This is stupid: the clothes hanging on the rod and the ones hanging from the hook are going to try occupying the same space at the same time -- I should move the hook toward the front wall."
The question then became "How much towards the front wall?" At which point I figured that someone had worked this out before, and probably someone in the DIYChatroom community would know it, hence, this post...
Richard
RichardZ is offline   Reply With Quote
Old 11-18-2013, 01:46 PM   #2
K&B Designer
Live_Oak's Avatar
Closet sizes vary. Put a hanger on the closet rod and then use the dimension halfway between the hanger and the wall for your hook placement. I don't personally see getting much additional storage out of the average closet by adding hooks. Unless it's only going to be used for scarves or a belt or two. Anything else will interfere with the hanging clothes.
Do it right from the beginning if you only want to do the job once. It'll be cheaper in the long term.
Live_Oak is offline   Reply With Quote
The Following User Says Thank You to Live_Oak For This Useful Post:
joecaption (11-18-2013)
Old 11-22-2013, 12:20 AM   #3
Rewards Points: 175
Thanks. In a way, I had the same sentiment as you: stuff hanging from hooks will interfere with clothes on hangers, so why am I doing this?!?
I'd add PJs to your short list.
In any event, I'll take your common-sense positioning advice (which in hindsight seems so obvious, but then the obvious all too often seems to escape us, which is often why common sense isn't all that common!).
Richard
Bedroom Closet Organizing trixie2396 Interior Decorating 10 09-19-2013 06:14 AM
Additional fan in closet Tankeray General DIY Discussions 11 06-04-2013 05:05 PM
Removing existing closet gnomonklater Building & Construction 4 12-02-2011 12:14 AM
Laundry closet decision LClark Remodeling 2 06-26-2011 06:19 AM
Hardwood closet threshold question DIY-Renovator Flooring 1 07-27-2008 04:42 AM
