High Ceiling Utilization - Interior Decorating - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Interior Decorating
Old 01-19-2008, 04:58 AM   #1
High Ceiling utilization
I have a large-ish 18x12 room with 12' ceilings that I am going to use for
a home office / media room. Basically... it's a 'rectangular box' with a door
on one end ( off center on a 12' wall ) and a 6'x6' window centered on the
other end. It has a concrete slab foundation with an attic over head.
Does anyone have any ideas ( pics ) for this space that will let me utilize
the high ceilings for storage or seating?
I'm thinking about having my 'office stuff' around the window ( facing the
door wall ) and having a drop down ( maybe 'fixed' ) media screen on the
'door' wall with a DLP Projector pointed at it.... I'll use Computer Room
type racks / cabinets for storage along one side wall. A few game room
type things along the other wall....
I see the 12' ceiling as wasted space.... I'd like to come up with some
type of design that lets me use a little bit of that space.
Thanks - jack
MrLinux is offline   Reply With Quote
Old 01-25-2008, 12:11 AM   #2
Thanks - jack
Depend on how you use that space. Consider the space for storage like you said, with accent "show" areas. Show areas are places where you put pictures a vase or some object the fits the area.
The first idea that comes to mind - depending on budget and taste - is a "stack" of boxes. Like a bookshelf but more rectangular, square, etc etc boxes all stacked to make it appear as one solid unit. You can also build a solid unit with different widths of shelves.
Kinda like this - tetris -
That on each side or one side with some more boxes going up to the ceiling and then over a window and down on the other side in a more "normal" manner would look very good and utilize the space.
Another cool solution would be adjustable shelves. Buy some galvanized steel pipes and run them floor to ceiling (they have things to attach them like that). Drill holes in the pipes and set, measured intervals. Next, make some shelves by creating squares or rectangles and drilling out the tops and bottoms to allow them to install on the pole so they slide up and down. Use the holes in the pole to insert pins as stoppers for the shelves (holds them in place). Woila! Adjustable shelves with a very modern look for a very nice price.
For a bold look - paint the wall a really nice color and stain your wood. Painting the shelves will work too
Good luck!
AbSoluTc is offline   Reply With Quote
Paint peeling off Bathroom Ceiling!!! armen30 Painting 17 12-08-2011 08:26 AM
Height of a ceiling fan with a trey ceiling? Bacardi 151 Electrical 7 09-08-2010 10:55 AM
Ceiling condensation icemand Building & Construction 1 12-15-2009 05:16 AM
ceiling fan support triplnikl Carpentry 5 03-06-2009 03:47 PM
Ceiling Joist Beam Construction? Stargazer Building & Construction 1 08-26-2007 10:50 PM
