Here's A Neat Trick - Interior Decorating - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Interior Decorating
Old 02-07-2008, 02:08 AM   #1
wfischer's Avatar
Here's a neat trick
All of the light fixtures in the finished portion of my basement are pretty much just bare bulbs attached to the joist, and then when they put in the drop ceiling, they cut a hole around the light and put in a piece of frosted glass, framed with wood. Unfortunately, the guest bedroom I'm working on was missing the glass... so I needed a cheap & easy alternative.
I found a large piece of window glazing acrylic in my attic, left behind by a previous tenant. It was broken, but still exactly what I needed: a clear piece of hard plastic, not more than 1/8" thick, and big enough to fit inside the wooden frame. I put some 100 grit paper on my random orbital sander, and tried it out on a test piece. It worked perfectly! After that, I sanded a big piece of the acrylic, cut it to fit in the frame, and voila! Faux frosted glass!
Pictures: Light fixture before & after (with light on and off), and the test piece.
Here's a neat trick-lightoffwithcover.jpg   Here's a neat trick-lightonwithcover.jpg
wfischer is offline   Reply With Quote
Old 02-07-2008, 10:22 AM   #2
very interesting.....
I wonder what it would look like with alternative colors. Not a bad idea in any sense, and a good way to use up scrap acrylic materials. Thanks for the post!
Last edited by AtlanticWBConst.; 02-14-2008 at 08:14 AM. Reason: Advertising Links Removed
rsmith1024 is offline   Reply With Quote
Keeping caulking trick deck hand Tools 8 11-15-2007 09:53 AM
Tub Drain Install - What's The Trick? Ricky D Plumbing 2 06-09-2007 07:22 AM
