Help With Paint Colour For The Garage And Front Door - Interior Decorating - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Interior Decorating
Old 07-06-2010, 06:58 PM   #1
Help with paint colour for the garage and front door
I don't know if there is a rule that says......
Garage door and front door colour, has to match some paint on the house? I am not happy with all that "Greyish" going on in front of the house, and am looking to break some of that up with some paint.
Looking at the links below, what is your suggestion for colours, am thinking of tapping into the brick colour and do some kind of reddish brown similar to the colour we used for the inside of the front of our previous house in the 3rd link
Some computer trickery, what do you guys think of the makeover, should I go for the brownish look for the garage and front door?
What do you think of this makeover for the garage?
http://community.webshots.com/photo/...55003884hoqLpb
syndicate1 is offline   Reply With Quote
Old 07-06-2010, 07:17 PM   #2
Painting Company, NY
housepaintingny's Avatar
Rewards Points: 616
There are no set rules, in general three colors are good, a body color, trim color and accent color, your door would fall under accent color, you can pick any color, choosing a color from your brick, a color from your roof. Shingles or any other interesting architecture on your home is a good start. www.kelloggspainting.com we have a page that's all about color selection with videos and a visualizer.
housepaintingny is offline   Reply With Quote
Old 07-24-2010, 01:07 PM   #3
lenozhka's Avatar
I would not do red on the garage door - that would make your house look too imbalanced/lopsided (you already have enough red/brick on the right side).
If you don't like the current gray, your other option is the same white you have on the trim and other woodwork. In fact, that's what I would do.
lenozhka is offline   Reply With Quote
Old 07-24-2010, 03:02 PM   #4
Thanks for that...so just white eh, nothing else you can think of?
Old 07-24-2010, 03:05 PM   #5
I think I'd do a darker blue for the garage & front door
....but I like blue
Old 07-24-2010, 05:37 PM   #6
lenozhka's Avatar
Unless you change the body or the trim color as well, white will work best (as boring as it sounds). You already have 3 colors going on (blue/gray, white and brick red), so in your situation it's better to reuse one of them instead of introducing a new one (that will not relate to anything and look out of place).
Hope this makes sense
Old 07-25-2010, 05:51 PM   #7
Drywall and Painting Pro
Sir MixAlot's Avatar
Rewards Points: 896
I agree with lenozhka.
White is your best option with your existing color scheme.
You could upload your picture to the Sherwin Williams Color visualizer-->https://www.sherwin-williams.com/visualizer/
and see what color looks best to you.
Sir MixAlot is offline   Reply With Quote
Old 07-25-2010, 06:08 PM   #8
It's really better not to add another color aside from the colors you already have. White may look a simpler color but it would fit in different color schemes you have already in home. My home is a white house, all colors outside are all white but the dramatic combination of colors is inside.
_______________________
Live in rooms full of light. ~Cornelius Celsus
home lighting
crizzyb is offline   Reply With Quote
Water Under Garage Door leted_82 Building & Construction 21 08-04-2010 04:18 PM
Garage Insulation DIYguy2000 Building & Construction 2 12-09-2009 07:41 AM
semi gloss enamel vs eggshell enamel NoExperience Painting 18 03-05-2009 04:57 AM
Challenge: Build a wall in front of Garage door pink toolbelt Building & Construction 4 11-12-2008 02:19 PM
Garage Door blade General DIY Discussions 2 06-02-2007 01:54 PM
