Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Interior Decorating
Old 08-17-2010, 03:11 PM   #1
Help to hang heavy mirror
Hello, I'm hanging a heavy (over 100 lbs probably) mirror on one of our walls. It has four keyhole-size hangers on the back, which I'm hoping are 16" apart (to match the studs).
What I'm wondering is what is the best hardware to use to mount it, and, any ideas on lifting it into place?
There will be two of us, but I'm trying to come up with some idea to minimize the strain on our backs!
Thanks, Rob
robwallis is offline   Reply With Quote
Old 08-17-2010, 04:32 PM   #2
framerman's Avatar
This answer doesn't help your keyhole situation.
When I've hung mirrors that big, I usually get those aluminum cleat hangers. Very easy to lift on and off, very rugged, 16" OC is not an issue.
http://govart.com/hardware_cleat.html
framerman is offline   Reply With Quote
Old 08-17-2010, 06:01 PM   #3
Tool Geek
PaliBob's Avatar
Good Tip from Framer
Can you imagine the problem of trying to wrestle the heavy mirror to line up with four fasteners that you may not have installed to be a PERFECT mirror image of the slots in your mirror.
Another consideration is that with Framer's Cleat you can perfectly center the mirror in your desired wall space.
You can weigh the mirror on a Bathroom Scale
Let us know how things work out
& Stay Safe
.....Bob Lavery
Hang a mirror by crown molding / trim? kennedy.greg Carpentry 1 03-22-2010 05:46 PM
Hanging a Heavy Mirror frapha1 General Discussion 6 01-03-2010 12:21 PM
Where to hang sconces at bath mirror - pic Leah Frances Remodeling 4 04-30-2009 12:33 AM
large bathroom mirror DK75 Remodeling 4 04-18-2008 06:27 PM
Running into difficulties installing bathroom mirror (pics of the nightmare incl.!) joeyboy General Discussion 18 08-10-2007 11:04 AM
