Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Interior Decorating
Old 08-13-2011, 11:20 PM   #1
Hanging Pictures
I have two identical sized pictures to hang but the problem is that the hanging wire on each of them are a different lengths.
In my last attempt (before I realised this) I aligned the hooks but the pictures hung at different heights due to the wire. I ended up guessing and having a lot of holes! I have now moved and don't want to have the same holey problem.
Any suggestions on how I can get it right first time?
dkt800 is offline   Reply With Quote
Old 08-13-2011, 11:58 PM   #2
Tileguy
Bud Cline's Avatar
Hanging Pictures
Yow.
Adjust the hanging wires so that they are the same on both pictures.
Old 08-14-2011, 03:07 AM   #3
Hanging Pictures
I had hoped to do that but it's covered underneath the materials used for framing and I'm worried I'll ruin it if I pull it up.
Old 08-14-2011, 05:19 AM   #4
m1951mm's Avatar
Hanging Pictures
Hook the end of a tape measure on the wire, pull it tight as if it were hanging from the end of the tape and measure up to the top of each picture. Write that measurement on the back of each one. Mark on the wall lightly with a pencil where you want the top of the pictures to hang and then measure down to the amount written on the back of each picture for the placement of each hook.
For most pictures I like to use two hangers. I find that they slip around much less (like when dusting) A really small one I do understand only using one. I do not like to see a picture hanging sideways, lol.
m1951mm is offline   Reply With Quote
Old 08-14-2011, 09:24 AM   #5
the Musigician
DangerMouse's Avatar
Hanging Pictures
Can you take photos and post them for us to see?
DM
[SIGPIC][/SIGPIC]Click
to see some of my original magic tricks and trick boxes!
Old 08-14-2011, 09:43 AM   #6
Hanging Pictures
I use this method. http://www.youtube.com/watch?v=7Z6Iz...layer_embedded
epson is offline   Reply With Quote
Old 08-14-2011, 06:33 PM   #7
Hanging Pictures
Hang one frame where you want it to be. Place 2nd frame next to it and draw a line on the top of the frame. On the back of the frame, pull wire tight as if it were hanging, measure from top of frame to wire. Mark the measurement on the wall and place your hook.
DecorMadeSimple is offline   Reply With Quote
Old 08-14-2011, 06:38 PM   #8
Experienced
Jackofall1's Avatar
Hanging Pictures
You could avoid the dilema altogether and hang the frames offset that way there would be no straight line reference.
Mark
Old 08-24-2011, 11:08 AM   #9
Hanging Pictures
Mark
I like this suggestion! I when I have two frames that I want to hang next to each other I always stagger them... that way you don't have to worry about it being exact and it looks nice!
dawg803 is offline   Reply With Quote
Old 08-26-2011, 08:24 PM   #10
Hanging Pictures
Thank you all so much for the suggestions! I'll get working on it now
Old 08-26-2011, 10:29 PM   #11
sdsester's Avatar
Hanging Pictures
My clients were art galleries. A show would come and go and all kinds of holes would be left. Get over it. I swear I know where all 4,000,000,000 are in one place but you will never see them if you walked in.
http://www.cinemagallery.cc/history_gallery.html
Plunk the photos you have nearest each other. If the photos do not match. Stretch the wire. Or move the anchor.
Really, look at the image I provided and imagine how many holes in walls have come and gone.
Use tape or something and a real painter may kill you.
Meanwhile? Put a hole in it. Wrong place? Move it. If the picture covers your mistakes you are in great shape unless someone moves the art piece. 30 years later in your home. Within 30-60 days in an art gallery.
Then you patch it, prime it and paint.
sdsester is offline   Reply With Quote
Hanging pictures without damaging wall or paint Mortimer Interior Decorating 8 09-28-2010 10:03 AM
Hanging punching bag in garage Isocene General Discussion 3 05-21-2009 09:20 AM
Hanging Pictures jamiedolan General Discussion 1 01-07-2009 05:32 PM
Posting Pictures rjordan392 Site Help and Suggestions 13 08-18-2008 09:25 PM
Hanging heavy pictures in an old house BlackRichard Carpentry 4 05-07-2006 09:35 PM
