Hanging A Picture Without Finding Stud - Interior Decorating - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Interior Decorating
Old 06-12-2014, 01:31 PM   #1
Rewards Points: 169
Hanging a picture without finding stud
I'm looking to hang two ~10lb pictures. The long and the short of it is that I can't put them on studs. Would a normal picture hook suffice?
RCGA is offline   Reply With Quote
Old 06-12-2014, 04:52 PM   #2
Jmayspaint's Avatar
Rewards Points: 534
I see big heavy pictures and mirrors hung on just drywall all the time. They seem to hold fine the first time. It's just when you take it down and put back the nails start to loosen up and need to be moved.
Jmayspaint is offline   Reply With Quote
Old 06-12-2014, 10:41 PM   #3
Rewards Points: 1,692
It is still prudent to use a drywall anchor of some type.
ED
de-nagorg is online now   Reply With Quote
Old 06-12-2014, 10:49 PM   #4
Rewards Points: 13,458
This is all I use for a wall anchor.
A simple trick is to predrill the hole using the Phillips bit, it makes it easier to insert.
Not sure how these people are breaking them when inserting in the reviews.
I use an impact driver to drive them and have never broken one.
http://www.homedepot.com/p/E-Z-Ancor...4?N=5yc1vZc2eq
Old 06-12-2014, 11:47 PM   #5
JOATMON
ddawg16's Avatar
Rewards Points: 1,454
I have to echo the same sentiment...
For small stuff....the simple picture hooks work fine.....wife wife is an artist....our house is FULL of pictures....no issues
Old 06-13-2014, 04:40 AM   #6
Rewards Points: 169
This is all I use for a wall anchor. A simple trick is to predrill the hole using the Phillips bit, it makes it easier to insert. Not sure how these people are breaking them when inserting in the reviews. I use an impact driver to drive them and have never broken one. http://www.homedepot.com/p/E-Z-Ancor...4?N=5yc1vZc2eq
So are you then just hanging the frame off of the screw? Or is a special type of picture hook needed?
Old 06-14-2014, 11:47 AM   #7
Search home depot for: World's Strongest Fastener Standard with Hook Plate (2-Anchors)
It won't let me post a link because I'm too new. I use those all the time and they are super strong and have a hook!
Sent from my Nexus 7 using Tapatalk
jsams is offline   Reply With Quote
Old 06-28-2014, 10:37 AM   #8
Rewards Points: 398
I use these and they work great - they come in different sizes for different weights. I'm not sure I'd trust the 50lb label rating, but I've used them for some large portrait frames (around 10lbs or so) and they have been hanging on my walls for years no issue.
Central New Jersey Area
adgjqetuo is offline   Reply With Quote
Old 06-28-2014, 08:35 PM   #9
Rewards Points: 169
Without a stud?
Old 06-28-2014, 08:39 PM   #10
Rewards Points: 398
Yeah, the nails are pretty long and at an angle.
Again, I wouldn't do 50lbs but 10 should be ok.
Use 2 hooks if you can (spread apart).
Old 06-28-2014, 09:19 PM   #11
concretemasonry's Avatar
Rewards Points: 2,594
It is much easier to get a good mount (centered and level) with wire cable on the frame that to try to use a loop on the frame if hooking the frame itself.
For anything over 10#. I habitually use two hooks because it is easier the level and the picture does not move with vibrations.
I have about 50 frames photos (a couple2'x4') with no problems. Hangers are cheaper than repairing weak attachments and fixing broken frames.
Dick
concretemasonry is offline   Reply With Quote
Old 06-29-2014, 09:48 AM   #12
Rewards Points: 264
Go with an OOK three-nail hanger by Hillman. Way above your specifications.
nanuk is offline   Reply With Quote
My first attempt at anything more than hanging a picture... DIbrYan Project Showcase 3 08-26-2013 11:59 AM
Help! Hanging plasma TV on lath and plaster wall monkeymonkey35 Drywall & Plaster 5 06-26-2013 07:46 AM
Hanging an aluminum awning mj12 Carpentry 2 02-26-2013 03:20 PM
Hanging towel rail without stud peter1 General DIY Discussions 11 03-11-2008 10:54 AM
Finding AC wires with Ryobi stud finder darsunt Tools 4 03-21-2007 07:43 PM
