Glue On Painted Walls - Interior Decorating - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Interior Decorating
Old 04-02-2011, 07:09 AM   #1
Glue on painted walls
How do i remove raised glue from painted walls
JULIA LACASKY is offline   Reply With Quote
Old 04-02-2011, 08:42 PM   #2
first, here's what happens if you try to paint over it: it mixes with the paint and makes a big slubby mess.
different ways to deal with it:
1. excision. cut out the area with a drywall knife and do necessary repairs before painting.
OR
2. partial excision. just cut deep enough to remove the glue, patch it with spackle, COAT the spackle with BIN White or Kilz. then paint finish coat.
if you do not coat spackle with a sealant like Bin or Kilz, you will get a different finish 'color' in paint due to absorption and texture differences. OR
3. Scrape, scrape, sand, sand, wash with TSP.
edit: or did you mean like a widespread area where wallpaper used to be?
in that case it's a major scraping/sanding operation (WEAR NOSEGEAR) followed by many TSP washings. if so, it might be worth it to totally replace the drywall. or if you can find a SAFE solvent to remove the glue that's an alternative.
oldkentucky is offline   Reply With Quote
Old 04-06-2011, 06:32 PM   #3
sand, prime, paint,paint. If paint is more than a 3 yrs old it may take a while for colours to match up.
painter162 is offline   Reply With Quote
Painted wood walls - couldn't take the depressing darkness! mrs1885 Project Showcase 6 01-09-2011 10:03 AM
What to paint over previously painted basement walls Atskodinski Painting 8 11-25-2010 05:08 PM
Paint options for basement walls and floors 68tele Painting 8 10-28-2009 06:09 PM
Floor Joists Lifting Off Foundation Walls?! cbeingessner Building & Construction 2 06-12-2008 08:39 AM
snading dust off new painted new sheetrocked walls purplezee Building & Construction 3 02-25-2007 04:59 PM
