Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Interior Decorating
Old 02-06-2009, 11:44 AM   #1
glue to a mirror
Id like to glue some wood leters (available at a craft store nearby) to a mirror (also some other things like a bike chain)...However, I want to minimize the uglyness of the glue on the backs of the letters (since you will probebly see them in the reflection on the mirror)...I was wondering what glue I should use (aka what glue dries clear and can apply both wood and metal to the verysmooth front of a mirror?)???(for example - typical crazy or super glue, epoxy of some sort, rubber cement, common wood glue)???
Leprichon is offline   Reply With Quote
Old 02-06-2009, 11:49 AM   #2
Tom Struble's Avatar
glue to a mirror
how about hot melt?
Tom Struble is offline   Reply With Quote
Old 02-06-2009, 11:53 AM   #3
glue to a mirror
Thanks for the quick reply...I dont have a glue gun, but if that is the best way to go than I can certainly borrow one...
Old 02-06-2009, 12:31 PM   #4
RippySkippy's Avatar
glue to a mirror
You could contact a local glass shop and inquire with them. I'd be tempted to look into clear silicone...but that can be god awful messy. Give some things a shot and report back!
when it comes to breakfast, the chicken is dedicated, the pig is committed.
LMASD
RippySkippy is offline   Reply With Quote
Old 02-06-2009, 12:43 PM   #5
Learning by Doing
Leah Frances's Avatar
glue to a mirror
To conceal the ugliness: Paint the back of the letters black - or the same color as the surrounding walls around the mirror. This helps hide their reflection.
To make it stick better: scratch the glass under where you want to glue. Of course, you don't want to do this if you will ever use the mirror for something else.
To glue it: loctite and others make glue for gluing rear view mirrors to windshields. I would try one of those glues - check out auto supply stores.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 02-06-2009, 01:07 PM   #6
Remodeling Contractor
glue to a mirror
use silicone. apply in a small round dab and it will not look bad. Contact cement will not work, since you need to coat both pieces. We use silicone to glue fish tanks together. Glass to glass, which needs to be very strong.
Old 02-06-2009, 02:51 PM   #7
glue to a mirror
great tip Bob actually glass companies sell a very clear silicone that's used in frame less glass shower door systems
Old 04-08-2009, 09:17 AM   #8
glue to a mirror
Elmer's have this glue that dries up to be clear. try that one out for your problem.
Dana11 is offline   Reply With Quote
Old 04-08-2009, 09:30 AM   #9
glue to a mirror
silicone Type I is different than Type II and is what the glass companies will use. Elmer's clear will NOT work.
Old 04-19-2009, 03:16 AM   #10
Title 24 Consultant
glue to a mirror
ask your local glass store and ask for some tips.. You can search on the internet perhaps to find some extra ideas regarding glues..
AllenB is offline   Reply With Quote
Hanging a Heavy Mirror frapha1 General Discussion 6 01-03-2010 12:21 PM
large bathroom mirror DK75 Remodeling 4 04-18-2008 06:27 PM
Wood Glue Issue gp1200r Carpentry 4 02-20-2008 12:56 PM
Running into difficulties installing bathroom mirror (pics of the nightmare incl.!) joeyboy General Discussion 18 08-10-2007 11:04 AM
How to remove these 'pads'? Solvents? Mechanically? (Pads on mirror!) joeyboy General Discussion 11 08-04-2007 07:01 PM
