Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Interior Decorating
Old 01-07-2009, 11:08 AM   #1
Learning by Doing
Leah Frances's Avatar
Furnishing long and skinny room
Any ideas about furnishing my sunroom? It is an enclosed porch and is merely 7 feet wide and around 33 feet long. Two doors enter from the house and exit to outside at 3 feet from one end and around six feet at the other.
__Ext door___<windows>____ext door_______
[__int door ________________ int door______]
We want to use the space for watching TV, informal dining, and home office.
Any ideas about breaking up the space? Or using furniture creatively?
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 01-07-2009, 11:36 AM   #2
bradnailer's Avatar
You can use the furniture to break up the areas in to three distinct sections. Maybe put the TV area in the middle and a small couch / love seat on each side with the TV on the interior wall. The other areas would sort of fall out of that.
bradnailer is offline   Reply With Quote
Old 01-22-2009, 08:50 AM   #3
You could also try and have the informal dining area in the middle. This will break up the room into three distinct parts.
@home is offline   Reply With Quote
Old 01-22-2009, 09:03 AM   #4
Learning by Doing
Any suggestions for a table in the informal dining area? The width is only 7 feet. I don't think it's enough room to have a standard table and chairs.
Old 01-22-2009, 10:12 AM   #5
typing left handed
A friend of mine had a similar set up on her porch, I think her width was closer to 10 ft, so I dont know if this can apply to your situation, but she had a drop table built onto the wall, (like the old fold out ironing boards)
it could seat 6-8 people and was easily tucked away when not in use. It looked like a shuttered window when it was closed...quite cute.
At the other end of the porch she had a smaller table for 2-3 that was long and narrow and had the fold down leaves at each end, and was better suited to sit against a wall rather than in the center of a room.
She also used a butcher block style cart on wheels that she could move around for work surface. She did a lot of built ins on all the wall space for storage and the media and had pieces serve multi functions to make her narrow space work for them as a family room and home office with the extra eating space option as needed. Also you might try searching through hgtv's archives, they have done narrow space makeovers on quite a few of their shows. Good luck!
jmb324 is offline   Reply With Quote
More On This Topic
Paint is the most dramatic choice you make when decorating your home. Paint color sets a space apart or creates a unified flow throughout your entire living space. Explore your color desires before you shop for paint. Do not be overwhelmed by the... Read More »
If moving walls is in your plan, there are several things to consider. You want to consider what is in the wall. Is there electric in the wall? Is there plumbing in the wall? Where is it? Where can you move it? Can you take it out? What would be the... Read More »
Not everyone has a spacious master suite with room for plenty of furniture and extra large walk-in closets. For those who a bedroom made for sleeping only, storage can become a problem. If you're creative, however, there are techniques to increase... Read More »
When decorating a long room, the idea is to trick the eye by creating numerous focal points and intimate conversation areas to soften sharp angles. Pulling the eye to the center of the room can be accomplished by angling rug and furniture placement. Here... Read More »
This area used to be a back porch where the ceiling drops down. This entire area was a back porch. This end segment of it was a laundry room. When we decided to make this an entry alcove, what we did was we had to end the plumbing here, we had to... Read More »
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
