Front Entry Door Paint/Color Advice - Interior Decorating - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Interior Decorating
Closed Thread
Old 04-06-2009, 12:27 PM   #1
gibear2k5's Avatar
Hello,
Wife and I decided to paint the front entry door. We are both trying to decide between white (color matched to siding) or blue (colored matched to shutters).
I'm going to change the hardware (deadbolt and handle) to satin nickel and install a satin nickel kick plate and knocker. Hopefully it will dress up the door until I can afford a replacement.
Any advice on the color choice?
How about some tips on painting the steel door?
Notice how the trim around the sidelights yellowed!
Photos attached: Thanks, Scott
Before (blue door and blue sidelights)
After (red door w/ white sidelights)
Last edited by gibear2k5; 04-21-2009 at 05:36 PM. Reason: Updated w/ complete photo
gibear2k5 is offline
The Following User Says Thank You to gibear2k5 For This Useful Post:
dgeer1217 (10-09-2013)
Old 04-06-2009, 01:22 PM   #2
Remodeling Contractor
Fusion paint makes a spray that will work on the sidelights. Oil is best for the door and spraying this is the best way to go. Blue will look much better than white. White will just not work well for curb appeal. If you need to brush it on, use enamel paint. In all cases be sure it is exterior. Better quality paints are worth the money and will be the only way to achieve good results.
Bob Mariani is offline
The Following User Says Thank You to Bob Mariani For This Useful Post:
lamonique (03-11-2014)
Old 04-06-2009, 01:40 PM   #3
gibear2k5's Avatar
Bob, is this what your talking about for the sidelight trim http://www.krylon.com/products/fusion_for_plastic/ the Fusion plastic white satin spray paint?
Figures, the wife is right! I want to be able to match the blue as close to the shutters, any thought on that?
Also, it's very apparent the original painter used a brush, the paint is 7 years old, should I sand the door?
Old 04-06-2009, 04:15 PM   #4
I would. Sand with 400 grit wet sandpaper and lots of water to avoid clogging the paper. The door will look better if it stands out. A color more like the shingles will work. Or a deeper more purple color. You need something that will work with the shutter color, but not the same. Again. Do not let it wash out, let it stand out.
Old 04-06-2009, 06:57 PM   #5
gibear2k5's Avatar
Played with Photo Shop a little. What do you think?
more purple:
Picture #1
or more red:
Picture #2
Old 04-07-2009, 05:18 AM   #6
Keep playing... you can surely see these do not work. Try BM soot # 2129-20
Old 04-07-2009, 05:53 AM   #7
like the 2nd image door color it is striking and looks good enough. Your walls are white dark colored doors will look fantastic.
Dana
Dana11 is offline
The Following User Says Thank You to Dana11 For This Useful Post:
Old 04-07-2009, 08:21 AM   #8
gibear2k5's Avatar
I like that BM Soot color, tried to match it - still a little off.
Picture #3
More brown:
Picture #4
Old 04-07-2009, 08:33 AM   #9
But #1 of this picture looks the best so far.
Old 04-07-2009, 08:56 AM   #10
gibear2k5's Avatar
I Attached the wrong Soot example (picture #3,) pictured below I believe is a closer resemblance to the sample color you recommended. I've also labeled each photo. Thanks for everyone's help!
Soot
Picture #5
Old 04-07-2009, 09:14 AM   #11
gibear2k5's Avatar
BTW, should the sidelights being painted white or color matched to the door?
Old 04-07-2009, 04:40 PM   #12
gibear2k5's Avatar
Picture #6 -
Old 04-07-2009, 04:43 PM   #13
no... Leave them white. It is the door you want to see. You seem to having more fun on the computer or is this to avoid the painting?
Old 04-07-2009, 07:25 PM   #14
gibear2k5's Avatar
You know it!! Don't want to repaint, once a decision is made. I have a couple of days to play with, since it's so unseasonably cold.
Old 04-07-2009, 07:56 PM   #15
picture #6 wins it looks much better than before
blk90s13 is offline
Closed Thread
Cost to replace entry and screen doors?? kiss44 Carpentry 6 01-30-2009 09:46 AM
Adding new Front Porch, need opinions MeraleeCrowl Remodeling 1 11-05-2008 12:47 PM
What is the best type of door stop for front entry door? KUIPORNG Carpentry 5 06-29-2007 04:23 PM
