Front Door Color Help - Interior Decorating - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Interior Decorating
Old 07-23-2009, 04:05 PM   #1
Rewards Points: 51
Question
Front door color help
Hi,
What color options should I consider for my front door and sidelights? It's hard to tell from the picture but my siding is a very light grey-green, called "stone" I believe.
Thanks!
deepstuff is offline   Reply With Quote
Old 07-23-2009, 04:25 PM   #2
Rewards Points: 602
IMO, it looks beautiful the way it is. Painting the door another color might detract from the nice trim. Just my 2 cents.
gma2rjc is offline   Reply With Quote
Old 07-23-2009, 04:45 PM   #3
My last house was white with a blue door
This house we have a red door
I like the front door to stand out
Old 07-23-2009, 07:53 PM   #4
rwa
rwa's Avatar
Rewards Points: 43
the entry should be a focal point ... make it stand out like Scuba said ... dark green or black
rwa is offline   Reply With Quote
Old 08-15-2009, 09:33 AM   #5
I agree the door could stand out, even though it does look nice as it is, it seems a little 'safe'.
anyhoo, I don't believe dark green or black would go with anything you have going on on your exterior as it is. I would recommend a rich wood finish whether it's a paint treatment or replacement. That would, at least, tie in with your roof and porch. Or pull one of the tones from either of those and bring it onto the door.
You could take a couple of pieces (or use both sides) of cheap plywood and paint with all of your color options, prop it in front of the door before leaving your house to go someplace and see how it looks when you return. OR prop the pieces and take pics like the one you posted and compare them.
Just my thoughts,
Nikki
chicuniques is offline   Reply With Quote
Old 08-15-2009, 02:05 PM   #6
Ivy green, look at the color chip that's closer to Hunter green, in satin finish.
Shamus
Shamus is offline   Reply With Quote
Ceramic or Porcelain for Front Room/Living room (advice needed) irishgem@ymail. Flooring 4 07-08-2009 01:46 PM
Tile on Front Porch PearlWhiteGT Flooring 8 04-24-2009 01:43 PM
Front Cement Steps / Porch Leaking bschwarz Building & Construction 2 04-14-2009 10:46 PM
Adding new Front Porch, need opinions MeraleeCrowl Remodeling 1 11-05-2008 12:47 PM
Cracked ledger board on front porch King_Doodle Building & Construction 20 06-03-2008 09:16 PM
