Is This Frame Hung To High? - Interior Decorating - Page 2 - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Interior Decorating
Old 06-17-2014, 01:59 PM   #16
JOATMON
ddawg16's Avatar
Rewards Points: 1,976
Get a higher head board....your existing one looks too short compared to the posts.
Old 06-27-2014, 01:30 AM   #17
Looks like it needs to be about a foot lower
rckdng is offline   Reply With Quote
Old 06-27-2014, 07:33 AM   #18
Search on the net.
kj123 is offline   Reply With Quote
Old 06-27-2014, 11:26 PM   #19
Yes, I think it is too high and there is more space between bed and that frame. This frame is too beautiful, but you have to reduce the distance between the bed and frame.
AlvinJackso is offline   Reply With Quote
Old 07-09-2014, 01:44 PM   #20
I think it's too high, but! Why not put a little shelf underneath it?
Pat Martin is offline   Reply With Quote
Old 10-31-2014, 03:07 AM   #21
Rewards Points: 108
I think it is in the right place, you said if you lower it, it will hurt in your head while sitting and that will look really bad. I think you don't need to lower that art.
RobertCurry is offline   Reply With Quote
Old 11-25-2014, 07:40 PM   #22
Yes it should be lowered a little bit. The rule of thumb is a frame should be hung at eye level. For beds I like when they're hung in place of a backboard (but not too low).
Frames4Less is offline   Reply With Quote
Carrier furnace short cycling between Low and High heat drtbk4ever HVAC 16 01-15-2012 08:38 AM
Condensation on fiberglass window frame creamaster General DIY Discussions 11 01-05-2012 07:42 PM
storm door frame vcerilli Carpentry 1 11-05-2011 02:35 PM
narrow frame dual pane windows tns1 Building & Construction 0 12-21-2010 02:05 PM
Raised tub - waterproofing solutions for wood frame against granite tile? lazzlazz Tiling, ceramics, marble 4 05-23-2010 01:15 PM
