Flaking Paint - Interior Decorating - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Interior Decorating
Old 04-28-2010, 09:10 AM   #1
flaking paint
Hi there,
i wonder if anyone can help. our old bathroom has paint on the ceiling which is partly flaking off in huge sheets (its above the shower enclosure and there is bare plaster underneath) but the rest of the room seems ok. Should I scrape just the loose bits off or all of it, and if so could I use joint compound to smooth the rough edges. Also what to do about the bare plaster patches?
regards
Les
Les Gordon is offline   Reply With Quote
Old 06-04-2010, 03:36 AM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 494
Remove any and all loose paint, skim where necessary, sand smooth, clean, apply Gardz, paint.
Install proper fan if necessary.
Old 06-04-2010, 01:36 PM   #3
Rewards Points: 150
chrisn is is right about the prep but I believe addressing the ventilation with a exhaust fan of some sort should be first. The big box stores have light/exhaust fan combos that won't break your pocketbook. Do your homework first, and figure out where you can safely vent the moisture that is accumulating and causing the flaking.
shapeshifter is offline   Reply With Quote
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 07:46 PM
semi gloss enamel vs eggshell enamel NoExperience Painting 18 03-05-2009 04:57 AM
Flashing NoExperience Painting 13 09-04-2008 05:56 AM
Semi gloss on Semi gloss mattpricemn Painting 6 08-25-2008 07:18 PM
