Fireplace - Need Ideas To Finish - Interior Decorating - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Interior Decorating
Old 04-14-2012, 09:06 PM   #1
Fireplace - Need Ideas to Finish
Help! Have been living with an unfinished fireplace (among other things) and am in need of ideas. The room the fireplace is in is 20' x 20' with cathedral ceiling, 25' at the peak. The problem is mainly how to finish/cover the exhaust vent, which extends approx. 16-18' up the wall. (photo attached). I think once that is determined, the easier it will be to decide on the surround.
Had initially thought about 'stepping' it, but then I thought of having to climb ladders to clean the 'steps'. However, if it is finished straight up, it makes it a very large thing and am thinking it would engulf the room. We plan to build-in book cases on both sides of the fireplace.
Any suggestions / photos would be appreciated!
StrwbrySC is offline   Reply With Quote
Old 04-14-2012, 09:27 PM   #2
Missouri Bound's Avatar
Straight up. Is a flat screen planned in the space over the fireplace....or a picture?
Do you want it your way or the right way?
Old 04-14-2012, 09:51 PM   #3
Flat screen now, replace with picture when (if ever) the basement media room gets finished.
Straight up to the ceiling? Or just enough to cover the vent?
Old 04-14-2012, 10:04 PM   #4
Extend the fireplace frame plumb up front and sides. Build your bookcases in and it's custom and very built in. Drywall, wood or stone, it's all good.
Old 04-20-2012, 07:10 AM   #5
Extend the finish out to the corners, or just highlight the fireplace. you will be able to access the interior design of your fireplace finishing.
glendoggett is offline   Reply With Quote
Tags
fireplace finish
Stone Veneer (ledgestone) fireplace remodel questions Augy Remodeling 11 09-17-2013 04:57 PM
Seal Peel and Stick Tiles? Echo1 Flooring 21 06-22-2012 09:07 PM
How to go about replacing fireplace surround? NewHomeDIYGuy Remodeling 9 01-26-2012 09:56 PM
Ideas on a thin or faux concrete finish to a table? groovmuffn Carpentry 3 03-20-2011 12:22 AM
temper glass for fireplace mantel shelf sil Interior Decorating 3 02-13-2008 08:10 PM
