Faux Wood Blinds ? - Interior Decorating - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Interior Decorating
Old 04-06-2013, 09:46 AM   #1
Rewards Points: 224
faux wood blinds ?
are there any issues with these ? i am considering them.
Fix'n it is offline   Reply With Quote
Old 04-06-2013, 03:42 PM   #2
Too Short? Cut it Again!
They will always look like faux wood blinds. Nobody lists faux wood blinds as property features to boast about when selling a property.
Why not real ones if that is the look you want? I get bombarded daily with some fairly decent prices from national blind companies that used to supply my projects with wood blinds, shutters and all. Do you have a real, not box store department, window treatment place near you? Or an interior designer? I would call them. Or visit a showroom. Believe it or not, an ID person may end up saving you lots of money over paying retail.
Old 04-07-2013, 10:35 AM   #3
Rewards Points: 224
the faux ones are cheaper. and i have seen real wood get badly sun damaged.
Old 04-07-2013, 11:10 AM   #4
DIY staff
Rewards Points: 7,174
If these are the foam filled slats---they become brittle with sun exposure and have a short life----
Old 04-07-2013, 11:42 AM   #5
Rewards Points: 224
idk what they are made from. i saw some in the store, and they looked to be solid plastic. i am looking at the 2"
Old 04-07-2013, 01:37 PM   #6
DIY staff
You might want to take a closer look at a hole or cut edge-----if foam cored---they don't last long----
Old 04-07-2013, 02:46 PM   #7
Do you mean like these ones?
While they are not as nice as California Shutters, they are not as expensive either. So you get what you pay for.
I bought these at Lowes 5 years ago and have had no problem. They are solid thick plastic
Not true ..I did have one problem... on a very large picture window..with a very large German Shepherd.. Directly at his sight level, where the faithful beast sat and waited for his beloved master (thats me) to return.. He ate one slat only, and damaged the surrounding two.
That window has since been upgraded anyway and I went with draperies for no reason other then a change.
Here is another pic with some Mardi Gras floats for your enjoyment
creeper is offline   Reply With Quote
Old 04-07-2013, 05:40 PM   #8
Rewards Points: 6,089
We have real wood...Two problems...in a sunny window they
slightly warp also you can't take them outside and hose them off
like you can the faux ones...I clean mine a slat at a time...
if I had to do it over I would have chosen a good quality faux one
that can be hosed off or dipped in a bathtub for cleaning.
Two Knots is offline   Reply With Quote
Old 04-10-2013, 09:04 AM   #9
I like mine just fine, they work very well! Definitely a good, cheaper option.
yipper is offline   Reply With Quote
Old 05-30-2013, 12:18 PM   #10
I like faux wood blinds better
Personally I prefer faux wood over real wood blinds due to affordability. After my living room hardwood floor had a huge warping incident, it made me realize how real wood is just very brittle and easy to destroy. Smallest bits of moisture can cause real wood to warp so easily. Also real wood doesn't have great flexibility so kids and dogs could be a big liability when it comes to blinds. I found a pretty good article with great content when I was choosing mine. Real wood vs Fauxwood
coffeex13 is offline   Reply With Quote
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 10:06 AM
Window treatment options? bokeh Interior Decorating 13 07-04-2011 01:30 PM
Basement Decorative Wood Wall Cover popping up tk3000 Building & Construction 8 10-29-2010 01:17 PM
Brick and wood flooring jhughesfam Flooring 1 08-18-2007 04:29 PM
Wood to Concrete without Drilling MattStata Carpentry 1 04-19-2006 05:16 PM
