-   Interior Decorating (http://www.diychatroom.com/f50/)
-   -   Exterior paint colour suggetions? (http://www.diychatroom.com/f50/exterior-paint-colour-suggetions-7977/)
melissa23 04-24-2007 02:21 AM
I'm looking to paint the trim/shutters/doors on my house - right now it's a god awful shade of blue/green and I'm desperately in need of a change! Everything I've come up with and held up to the siding ends up looking dull and washed out and I'm at a complete loss :(
The siding looks a bit grey in the picture but it's actually white (sorry the photo is so small!).
http://img.photobucket.com/albums/v4...ne/6937261.jpg
Any suggestions?
Thanks much :)
Melissa
trptman 04-26-2007 10:54 PM
What is the siding material?
The picture is small but it looks like vinyl. If so, are you sure you want to try to paint it? Thats the one and only good thing about vinyl-eliminates the maintenance of painting.
If you decide to go ahead and paint it, I've been told you can't paint it any darker than it already is. The reason being is that vinyl will expand with the suns heat quite a bit and darker colors absorb more heat, exaggerating this. This in turn will eventually cause the paint to fail and start coming off as it can't expand and contract as far as the siding.
I do alot of wood painting, but steer clear of trying to paint vinyl unless someone has come out with a product that will adhere reliabley to vinyl.
Assuming your'e going to paint- I would'nt do anything bold. You don't have an ornate victorian to absorb an elaborate scheme and the surrounding houses look pretty bland. The setting is always a factor for what to paint a house.
Paint Stores (and I'm a big fan of Sherwin Williams products) usually will have an array of color chips already put into compatable combinations for you to consider if you really have no idea what you would like.
For a simple but traditional color scheme that I like to use, and would probably work for your house is some shade of creamy yellow, white trim and dark green shutters . I especially like the Sher. Will. color "Rookwood Shutter Green". It is the perfect traditional dark green exterior color for -you guessed it- shutters and other trim. Ask for it by name if you want the right dark green
You are right, whatever you do get away from that awful teal. As for the white trim, I would recommend something a little off white. It will still "look" white but a pure white will look too sterile.
Keep in mind this is just one possible combination of about a million you could do.
If your house is indeed vinyl, ask about any newer products to deal with vinyl.
I only paint older homes and buildings so I have limited experience in newer building products.
Hope this maybe helps....a little at least
trptman 04-26-2007 11:00 PM
I just re-read your question and I now see you aren't looking to paint the siding. Thats what I get for not taking my time to read more carefully.
With white siding....that a tough one. Sometimes white trim works but I'm having a hard time picturing white siding with anything other than ...white trim, and not have it look odd. Ive seen it tried, but it always looks odd to me with a white body color and some darker trim color. To my eye it looks backward.
You might be best off just changing the teal to something else and living with the white on white.
J187 04-27-2007 08:32 AM
1 Attachment(s)
How about a nice tanish green color?
Maybe a more pale shade will be good. I think it would look quite nice. Below is a quick photoshopped idea. I really like it though.
joewho 04-29-2007 02:39 PM
The dark roofing and numerous shutters make it hard to choose a color.
I would try some reds, but again, the dark roofing comes into play.
How about hunter green?
Miss3D 09-09-2007 01:07 AM
what it you do?
HI. I just found this discussion and believe it or not I am having the SAME dilema-- large house, white siding, dark roof and dark bluish-green trim that I don't like. I thought the lighter green trim suggestion looked good, but I'm curious if you made your decision and what have you might have done? Anyone else have new suggestions? It IS a tricky choice. Too bad I'm not up for painting the whole thing, but the siding is good for many years and I don't want to mess with it.
jkchapp2 09-10-2007 11:57 AM
I know you are looking for color, but...how about Black shutters with a Red Front Door, Red trim around the frame of the garage door with the Garage Door being Black. Make sure you do not use to harsh of red. Are the window frames wrapped, trim them in the Red color.
Miss3D 09-10-2007 11:16 PM
what's black, red and white all over?
1 Attachment(s)
Hey thanks for the suggestion of red and black trim! I kind of like it, and did a rough sketch in photoshop. My friends think the black will fade to a paler shade of ugly, though. Maybe my local paint guy would have some advice on that. Anyway, I don't have shutters and not sure it would look right with the window frames all red, so maybe it's missing something. What do you think? I'm not sure it works on a large house.
I have changed the landscaping since this photo and will continue to develop more of a natural/Japanesey look outside, replacing the rotting picket fence and building a nice archway entrance to the house, etc. Sorry this photo is so bad!
treetoplma 09-11-2007 05:24 PM
paint color
The real issue may be you have too many good, possible choices. This would take me at least 2-3 of weeks to figure out. I suggest painting the shutters and garage door the same (less bold) and the front door something different (more bold). They could be complimentary colors, or they be different shades of the same depending on how bold you are. Drive the neighborhoods and find which colors you like (and don't) to help narrow the choices. Do you want to play it safe & blend in or take a risk & stand out? Some colors are more inviting than others, and you want your front door to be inviting (or do you?). Most of all, buy sample sizes to try it out first. lma
interiordecor 09-12-2007 12:13 AM
For small spaces, use lighter colors to get the spacious feel.
For large, empty rooms, use darker colors to tighten it a bit and to make it more intimate.
If your room project is very susceptible to dirt or is exposed, glossy shades are better over matte.
If you have large paintings and carpets inside that room, use it as your basis to get complementary colors. :thumbsup:
AtlanticWBConst. 09-12-2007 04:20 AM
:huh: ?
What does that have to do with this thread?
.....This thread is about: " Exterior paint Color Suggestions"....
funnyguy 09-28-2007 04:50 AM
I would paint the garage door white, with the trim and shutters the same color, say kaki, with a red door. Don't want that garage door jumping out at you.
Jeekinz 09-28-2007 03:55 PM
Originally Posted by AtlanticWBConst. (Post 62600)
:huh: ?
Plus, I could never understand the whole "lighter colors, small rooms" thing. I just don't get that. I understand the principal, but any time I painted a small room a darker color, it looks the same.
melissa23 04-06-2008 11:37 PM
So it's like 7 months later and still no decision LOL warmer weather is fast approaching and I need to paint soo or it just won't get done :P
What do you all think of this idea;
http://img.photobucket.com/albums/v4...e/Picture1.jpg
The top colour for the shutters & garage and the bottom colour for the trim & metal flashing. And then something bold for the front door?
melissa23 04-06-2008 11:38 PM
I really like that tannish green colour too! Thanks!
