Door Frame Chipping - Interior Decorating - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Interior Decorating
Old 08-13-2011, 01:00 PM   #1
Door Frame Chipping
I have no idea how to describe it.
This is what I mean: http://www.polycell.co.uk/guides/rep..._doorframe.jsp
I need some sort of plaster to fill in the gap of the chipped door frame. Are there any products from B&Q/Homebase you could recommend please? Also, since the colour of the doorframe is a peachy yellow colour, can I paint over what is already chipped and filled in?
diynoob2011 is offline   Reply With Quote
Old 08-13-2011, 04:10 PM   #2
m1951mm's Avatar
Normally you would use caulk between the frame (also called casing) and the wall. If you do a search about how to caulk (best advice is under the Painting section of this site) you will find some great information on how to solve your problem.
If the chipping is really bad you would want to remove any loose stuff (a 5 in 1 tool is the best to do this with). You would then need to do a prime coat before applying new caulk. You need to make sure that the raw plaster and or wood has a coat of primer on it before recaulking.
If you REALLY want smooth 45% angles between the wall and the frame, you would first smooth on joint compound or a very good spackleing compound on the wall first. Sand that down and prime it, caulk will not stick to something that is not primed or painted. Then do the caulking between the frame and the wall. Once you have chipping without much preparation you will never get a really true edge (you might even have to spackle the small edge of the frame, sand and prime and do a final caulking) it just depends on how perfect you want it.
m1951mm is offline   Reply With Quote
The Following User Says Thank You to m1951mm For This Useful Post:
diynoob2011 (08-14-2011)
Old 08-14-2011, 05:55 PM   #3
Polyfill was used in the video, wood filler can also be used for wood doors. Sanding would more than likely be needed with wood filler.
Use a primer over the repaired area before painting.
DecorMadeSimple is offline   Reply With Quote
How to repair Concrete chipping outside of house T_MB General DIY Discussions 7 05-11-2011 05:47 PM
Porch floor paint chipping AMThompson Painting 1 09-23-2010 09:15 AM
Large pieces of paint chipping off mastrohome Painting 1 12-27-2009 09:54 PM
Paint chipping on trim and doors. RR33 Painting 9 12-30-2007 07:26 PM
Old Paint Chipping Off daveofnj Painting 5 10-06-2007 09:29 AM
