Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Interior Decorating
Old 08-15-2007, 11:46 AM   #1
Display Problem
Hello all!
I'm doing our home office in a vintage aviation theme and have actually been able to purchase a wooden propeller!
I don't want to attach any anchors or screws to the piece itself.
Does anyone have any ideas on how to display it other than setting it on a shelf? I think it would be fun to display it on an angle rather than horizontally. I do NOT want a clock in the center.
Thanks in advance.
shapeshifter is offline   Reply With Quote
Old 08-15-2007, 11:35 PM   #2
Display Problem
There should be holes in the propeller itself used to mount it to the drive shaft. My suggestion would be to use one of those to mount it to the wall, then put a short screw in each of the other holes to make it look even.
Steve
PainterMatch.com - the best place to find a painter!
StevePM is offline   Reply With Quote
Old 08-16-2007, 07:14 AM   #3
Agent 000
SecretSquirrel's Avatar
Display Problem
Hey... I would look at making an adapter to bolt that puppy up to a ceiling fan. It would be the talk of the town
SecretSquirrel is offline   Reply With Quote
Old 08-16-2007, 12:23 PM   #4
Display Problem
Thank you both for the feed back. I had not thought of using the existing holes as a way to mount it. I could mount it on something that could be moved about.
I love the ceiling fan idea however, the thing is 52" long and weighs a ton. Clearly it was milled from a single piece of wood.
Old 08-16-2007, 01:46 PM   #5
Agent 000
Display Problem
Well I just don't see this as being a problem. We could mount a 5 hp motor up in the ceiling but that might require new footings for the support beam. But that's ok, Hmmm what else... oh yeah, an upgraded electrical service, vibration dampers for the house, a permit from the FAA... all do-able! And you call yourself a DIYer??? Tchh tchh tchh
Old 08-16-2007, 04:32 PM   #6
Custom Cabinet Maker
Display Problem
hmmm, small ball bearing lazy susan mounted to stud, make adapter plate with 2 thru bolts to prop hub, mount to lazy susan NOW u can place at any angle whenever it suits ya .
SS, 5 hp eh? then YEAH rip that cheapo fan out and replace it with the prop and get a REAL FAN LOL LMAO
JackM
skymaster is offline   Reply With Quote
Old 08-16-2007, 09:39 PM   #7
Display Problem
I have visions of my house being lifted off it's foundation as the propeller beats the earth into submission!
Old 08-16-2007, 09:43 PM   #8
Display Problem
BUT AHHHHHHHHHHHHHHH think of the cool breezes that such an event would create. The VIEW Oh Ye of little faith ROFLMAO
JackM
Old 08-16-2007, 10:19 PM   #9
Display Problem
More On This Topic
People collect many things. Stamps, sports memorabilia, figurines and even spoons. If you have a spoon collection that you want to display, you here are some tips for showcasing your collection. Read More »
Decorating with alphabet flash cards is a fresh, fun way to make a visual statement in a room. The cards look wonderful displayed in a baby’s nursery, a child’s play room, a library or even your living room--especially if you’re a... Read More »
Hi, I’m Mike Camelin with SunState Aviation Flight School in Kissimmee, Florida for Expert Village and today we’re going to be talking about the main parts of the exterior of the aircraft. Now the main body of the aircraft is what is referred... Read More »
Collecting vintage Valentine cards is a fun way to get an introduction to collecting as well as learning a little about history. Here are some things to keep in mind when getting your vintage Valentine card collection off to a great start. Read More »
Transferware Buying Tips
Transferware Buying Tips by Expert Village
When you make a choice as far as color or maybe you will be choosing to buy any number of these colors or maybe you want a mix but when you go to purchase a piece of transferware. I highly recommend that you buy the best piece you can buy in the price... Read More »
Door -Storm Door problem bassman Building & Construction 2 01-17-2007 04:16 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 02:51 PM
A/C Thermostat Problem therumblefish HVAC 7 11-01-2006 09:08 PM
Drywall, Mold Problem due to Leaked Water june03 Building & Construction 2 10-31-2006 08:24 AM
Problem W/ Power after Switching Outlets... G19-Fanatic Electrical 17 08-28-2006 02:55 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
