Direction Of Laminate For Long Narrow Room - Interior Decorating - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Interior Decorating
Old 10-20-2013, 10:01 PM   #1
I'm putting new laminate on my main floor. The length of the living/dining room is 23', the length of the kitchen is 10' (the kitchen is where the picture was taken from). The width of the living room is 10', and there will be a full height built-in cabinet sticking out a foot on the L shaped wall. The same laminate will run throughout the whole floor, with no transition between the living room and kitchen. I've read that running the laminate width wise in a long narrow room makes it seem bigger, but my floor installer says that it should always run length wise, and towards the windows. Suggestions?
fdiddy is offline   Reply With Quote
Old 10-21-2013, 06:30 AM   #2
I've always thought it should run in the longest direction. Lengthwise. In your case, toward the windows
creeper is offline   Reply With Quote
Old 10-21-2013, 01:35 PM   #3
Rewards Points: 6,089
In my opinion, since your room is narrow, I would run it the other way
to make it appear wider...
We have hardwood, and it runs across (not towards the windows) and it looks fine.
( I know -- in our case, it's perpendicular to the floor joists, so it's
not by choice that our hardwood was run that way)
Since your room is only 10 foot wide, I am wondering if your
installer is suggesting the other way (lengthwise)
because it would be less cuts, thus less work...but, what do I know...
I'm just a woman that figures thing out by reasonable deduction,
as well as factoring in what I like.
What are the opinions of the pro floor installers here?
Two Knots is offline   Reply With Quote
The Following User Says Thank You to Two Knots For This Useful Post:
Startingover (11-03-2013)
Old 10-21-2013, 01:52 PM   #4
Thanks for the replies. My installer said that he doesn't care which way I choose and either way would be the same amount of work.
New laminate floors in kitchen and living room Cmonica30 Flooring 5 01-06-2012 04:34 PM
Laminate flooring direction.. odd? casper129 Flooring 2 12-27-2011 11:56 PM
which direction do you run laminate? wheatiesb1 Flooring 8 05-05-2008 11:26 PM
Tile and laminate, or get rid of tile? kfoster Flooring 10 03-17-2006 03:14 PM
