Diagram Of Dual Hot Water Heater (s) In Parallel Not Series Having Flow Questions-- - Interior Decorating - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Interior Decorating
Old 02-27-2008, 07:48 AM   #1
Diagram of dual hot water heater (s) in parallel not series having flow questions--
We have dual hot water propane heaters and want to run them in parallel
We have a constant flow pump installed for immediate hot water access.
We have Cold In at a "T" between heaters and Hot Out has a "T" between heaters and is sent to the house
Question.............Where shoud the Return Flow be piped in? , equally to the drain valves or to the Cold In with a 1-way valve
Thanks a bunch
timlltt is offline   Reply With Quote
Old 02-29-2008, 03:01 AM   #2
Try posting in the plumbing section.
redline is offline   Reply With Quote
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
Water heater problem bear1957 Plumbing 23 11-01-2007 03:53 PM
Gravity Hot Water Recirculating Loop Questions harleysilo Plumbing 2 02-06-2007 03:28 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
Draining a hot water heater singforsupper Plumbing 1 06-07-2006 06:01 PM
