-   Interior Decorating (http://www.diychatroom.com/f50/)
-   -   Diagram of dual hot water heater (s) in parallel not series having flow questions-- (http://www.diychatroom.com/f50/diagram-dual-hot-water-heater-s-parallel-not-series-having-flow-questions-17733/)
timlltt 02-27-2008 07:48 AM
We have dual hot water propane heaters and want to run them in parallel
We have a constant flow pump installed for immediate hot water access.
We have Cold In at a "T" between heaters and Hot Out has a "T" between heaters and is sent to the house
Question.............Where shoud the Return Flow be piped in? , equally to the drain valves or to the Cold In with a 1-way valve
Thanks a bunch
redline 02-29-2008 03:01 AM
Try posting in the plumbing section.
