Design Question: Fireplace Foundation Nook - Need To Put The TV There - Interior Decorating - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Interior Decorating
Old 01-04-2017, 02:53 PM   #1
Rewards Points: 12
Design question: fireplace foundation nook - need to put the TV there
Hi there,
Looking for some advice - I'm finishing my basement and my foundation has a notch in it for where the fireplace is above. I have no idea why they do this, but every new-ish house I've seen in this part of the country has that. Basically the outline of the foundation matches the main floor, and the outside wall is notched out for the fireplace.
In my basement I plan to put our big screen TV against this wall. Originally I was going to frame it flat with the walls from 48" up and mount the TV above and put a TV component stand beneath. However I'm not sure this will be the best approach - a 70" TV 48" off the ground may be uncomfortable to watch.
Any suggestions on what to do with this space? I'd rather not board it up entirely.
See pictures attached.
Thanks in advance!
Design question: fireplace foundation nook - need to put the TV there-basement_v2.0_3d_1.0_-_sketchup_make_2017_2017-01-04_15-40-50.png   Design question: fireplace foundation nook - need to put the TV there-basement-cut-out.jpg
montydog is offline   Reply With Quote
Old 01-04-2017, 05:09 PM   #2
JOATMON
ddawg16's Avatar
Rewards Points: 2,108
Re: Design question: fireplace foundation nook - need to put the TV there
It's a perfect spot for shelves to put the AV receiver, DVD player, DVR, etc.
ddawg16 is online now   Reply With Quote
Putting in foundation - ufer question WillK Electrical 17 02-16-2012 04:31 PM
Insulation question around fireplace ryan5068 HVAC 3 09-20-2011 07:22 AM
What correct mix for building a stone foundation wall? & correct mix for stone fireplace. world travler Building & Construction 0 08-04-2011 06:39 PM
Fieldstone foundation repair question fieldstone Building & Construction 1 06-16-2011 11:02 AM
Permanent Wood Foundation Question opee Building & Construction 2 03-19-2007 09:27 AM
