Decorating Cinderblock Wall - Interior Decorating - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Interior Decorating
Old 12-21-2011, 05:17 PM   #1
decorating cinderblock wall
Hey its jus inquiring on any tips on decorating cindrblock wall. It's the base of a bar and was thinkin of using a backsplash pattern instead of fussing with attaching wood.
Do I attach tiles like I normally would to wood? I've never attached a backsplash before. So any help wild be great
Aloha1 is offline   Reply With Quote
Old 12-21-2011, 06:35 PM   #2
natwlsn's Avatar
Yes, you can tile a cinderblock wall .... as for all surfaces, be sure it is as smooth as possible, meaning there are no large protrusions and be sure it is totally clean, especially from any oils.
Cinderblock is safe because it doesn't shift or move. You can definitely dress it up nice. ... Consult a tiling expert for any concerns if your wall has been painted or any other coating applied to it.
Backsplashes are rather easy ...be sure to give the mortar at least 24 hours to dry before you put on the grout.
natwlsn is offline   Reply With Quote
Basement Concrete Wall Framing Against Stairs Epicsoccer Remodeling 7 01-13-2013 03:11 PM
How to calculate total glazing allowed in a wall? dalepres Building & Construction 3 04-22-2011 12:28 AM
Breaking up a long/continuous wall tigereye Interior Decorating 4 03-08-2009 03:43 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 01:01 PM
