Corner Blocks & Base Moulding - Interior Decorating - Page 2 - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Interior Decorating
Old 05-06-2013, 09:04 PM   #16
Architectural Sculptor
RWolff's Avatar
Rewards Points: 502
I prefer plinth blocks just as the photos by Two Knots shows! dang that looks fine! The plinth blocks jazz up an otherwise BORING baseboard, it is personal preference what you do in regards to the blocks, experiment and see what YOU like best, there's no law that says you must make YOUR baseboards or plinth blocks or moldings a certain way, certain size or anything else.
RWolff is offline   Reply With Quote
The Following User Says Thank You to RWolff For This Useful Post:
DiyCR fan (05-06-2013)
Old 05-06-2013, 10:05 PM   #17
Thumbs up
Originally Posted by ProudlyBuilt.co View Post
In general, you want to match what reveals there are on existing millwork. If using 1/2" baseboard without any "heavy" profiles...keep the reveals to 1/4" or 5/16"...making your 13/16" acceptable.
Please let me know what you go with in the end. Pictures are always helpful too!
Luke
thx, my reveals are 1/4" or less
corner blocks & base moulding-img_0241-fav-fb.jpg   corner blocks & base moulding-img_0243-fav-fb.jpg
DiyCR fan is offline   Reply With Quote
The Following User Says Thank You to DiyCR fan For This Useful Post:
oh'mike (05-07-2013)
Old 05-08-2013, 10:52 PM   #18
Rewards Points: 744
I'm not sure why you would need to make any coping cuts on base molding. Miters, yes, but not copes. And it looks like you had to do some miter cuts anyway.
Seattle2k is offline   Reply With Quote
Old 05-08-2013, 11:55 PM   #19
i'm a bit confused on your comment... i didn't make any coping or mitering at all, except for simply using a coping saw to cut the base moulding for the exact length i needed... i bought the corner blocks from Midwest Mouldings & Millwork. They cut em (glued 2 pieces together) to my exact obtuse wall angles which were all different...made my DIY job much easier
Finding the Proper Tool - Adding Rosette Blocks to Existing Moulding Thadius856 Building & Construction 8 08-19-2011 08:00 AM
Cinder blocks not intersecting at corner of foundation. OK? mjjstang Building & Construction 0 07-29-2011 10:37 PM
crown molding corner blocks ckr31 Carpentry 19 12-16-2010 07:23 PM
one corner of secornd floor room is low 99th_Flyby General DIY Discussions 9 01-12-2009 09:25 PM
Replacing a corner post, Reinforcing the wall? jlawrence42 Building & Construction 5 08-21-2006 12:41 PM
