Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Interior Decorating
Old 03-02-2010, 05:15 PM   #1
Question
colored concrete slab and plaster--color combo help please!
We are shortly breaking ground on a small solar (zero net-energy!) ranch and the only interior details we are settled on are 1) we will have a blank slate of unpainted, unfinished plaster walls and 2) our entire floor will be a colored concrete slab, a medium red brick color--very uniform color maybe with a little wax shine. (Think tennis court surface, a little nicer.) We need to keep the concrete exposed (passive solar features, to soak up the sun) so there is going to be a lot of uniform brick colored-concrete to be dealt with. What are your suggestions for complementing this flooring? Tinted plaster? Skim-coat or textured? Paint the plaster? We have an open layout with the living room, kitchen and dining areas as smaller rectangles within the 18X24 rectangle that is the great room. Thanks!
theriddler71 is offline   Reply With Quote
Tags
color schemes, coloring cement, interior design, plaster
Venetian Plaster FYI Plaster Ayn Painting 10 07-01-2010 12:26 AM
Help! Tile-over-concrete slab problems jeffchri Tiling, ceramics, marble 6 12-24-2008 06:22 PM
Plaster Walls - Did I screw up? jamiedolan Building & Construction 5 11-07-2008 01:10 PM
