Ceiling Fan Medallion, Any Tricks To Install? - Interior Decorating - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Interior Decorating
Old 10-27-2007, 06:56 PM   #1
Ceiling fan Medallion, any tricks to install?
Like the look, saw a few on ebay for about $30 shipped. I dunno exactly what you need to do to install them. The majority of them seem to made of plaster. Do you just put on liquid nails on it and put it in place? Are the mounting trim of the ceiling fans usually the same diameter?
Here's a pic of one installed.
Bacardi 151 is offline   Reply With Quote
Old 10-29-2007, 10:25 PM   #2
DeeTee's Avatar
I had one of those once in a fixer-upper I moved into. If I remember right the ceiling fan base went against it.
___________________________________________
Precision is always relative to the surrounding degree of perfection.
News Views Tips Commentary Downloads at the Construction Informer
DeeTee is offline   Reply With Quote
Old 10-30-2007, 07:19 PM   #3
Rewards Points: 1,448
Lowe's and HD have a few different versions of these as well. Probably about as good on the pricing as you may find online too.
As far as mounting, the smaller, lightweight plastic versions can be held in position by the flange of the fan itself, although I've used Liquid Nails on a couple of those.
And I used Liquid Nails on one of the much larger ones (dining room). I placed a piece of 2x4 across the face of the medallion and braced it with a 2x4 to the flooor until the glue had set.
ktkelly is offline   Reply With Quote
Old 10-30-2007, 09:24 PM   #4
Even online, lowes lists three while HD lists none. Trying to think if there's a cheaper easier way to hold it in place rather than an 8' 2x4.
Old 10-31-2007, 08:57 AM   #5
Tell the wife "Hold This, I'll be back in a minute"......
Old 11-08-2007, 09:09 PM   #6
Extreme DIY'r Adk's, NY
Rewards Points: 272
4 strips of UHB 3m double sided tape, cons adhesive in between if you're really crazy, caulk the gap when dry, ...never let your wife change her mind. lol
crecore is offline   Reply With Quote
Tongue and Groove Ceiling install....questions... Dr. Jim Remodeling 9 04-08-2012 01:14 PM
Paint peeling off Bathroom Ceiling!!! armen30 Painting 17 12-08-2011 09:26 AM
Ceiling condensation icemand Building & Construction 1 12-15-2009 06:16 AM
Can I install 12x12 porcelain tile on a shower wall or ceiling? dezigner80 Remodeling 6 09-15-2009 01:05 PM
Cost to install dropped ceiling tile??? timthetoolman Building & Construction 4 06-08-2008 10:06 PM
