Ceiling And Crown, Competing Whites? - Interior Decorating - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Interior Decorating
Old 01-10-2011, 10:52 PM   #1
Ceiling and Crown, competing whites?
Hi there all,
I'm relatively new to the DIY stuff, as is my husband, but we've had a great time so far working on our baby's room.
We are having a quandary about what to do with the ceiling. We have 9ft ceilings, and we did the room in Behr February Frost (full strength) with a chair rail done in a cool white color and above the chair rail the same color (Feb. Frost) at 50% strength - so it's a bit lighter up top.
We've also added crown moulding, in the same white as the chair rail, and my husband is going to do the baseboards that color as well, but we have no idea what to do about the ceiling. The ceiling is currently the color that the builder put in (Whisper White - like a warmer white).
Should the ceiling be the same color as the crown? Can you have two competing whites or will the ceiling just look dirty now that the trim seems a bit brighter? What about the doors? Our whole house was painted white to start, which was nice, but now we're here and not sure what to do as neither of us has done this before.
Thanks in advance for any advice.
SuznJosh is offline   Reply With Quote
Old 01-12-2011, 08:39 PM   #2
trish12's Avatar
Whites can be a little tricky because they often have an undertone that when paired up with a true white can begin to look yellow, pink, or blue. It's hard to say whether your crown moulding will emphasize the undertone of the ceiling color without knowing what the exact name and brand.
With the wall color you've selected, I think that as long as the ceiling doesn't read 'pink' it will look fine. It all depends on what look you are after; If you want the crown mouldings to stand out more then I would say keep the current ceiling color but if you want the mouldings to blend in, then I would paint the ceiling the same color.
As for the door, I would probably paint it the true white color even if you end up leaving the ceiling as is.
Hope this helps; Good luck.
--Inspirational Room Design--
trish12 is offline   Reply With Quote
Crown moulding: Flat ceiling to angled wall question RP31 Carpentry 19 10-30-2012 03:18 PM
Crown Molding to ceiling gap question? Zerosignal Carpentry 12 01-27-2011 05:52 PM
Help with crown moulding in tray ceiling JennyT Carpentry 2 03-01-2010 11:09 AM
Need help on Crown Molding on inset Trey Ceiling pacumming Carpentry 2 01-30-2010 12:13 AM
Crown molding - uneven ceiling jelly Carpentry 9 01-05-2010 06:24 AM
