Carpeting Gets In Paint - Interior Decorating - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Interior Decorating
Old 10-11-2011, 07:10 PM   #1
caroln242's Avatar
carpeting gets in paint
Any ideas how to keep carpeting off the paint when you paint baseboards? I used a ruler to hold down the carpet, but it just springs right back up and sticks to the paint!
caroln242 is offline   Reply With Quote
Old 10-11-2011, 07:47 PM   #2
MikeKy55's Avatar
Rewards Points: 254
If the baseboard was held up off the floor when it was installed, you may be able to slip cardboard about 4 inches wide under the baseboard. Paint down to it and after the paint tacks up good pull it out. By then the carpet won't stick to the paint.
Just thinking out loud.
MikeKy55 is offline   Reply With Quote
Old 10-11-2011, 07:47 PM   #3
DIY staff
Rewards Points: 7,174
I have had good results using painters tape or masking tape to protect the carpet and temporarily
pull it back from the trim---It's a bit of a learning curve ---the tape is tucked in like a bed sheet--
Old 10-11-2011, 08:01 PM   #4
caroln242's Avatar
Hmm, both good ideas! If the cardboard trick doesn't work, I'll tape it. Sounds easier than prying carpet loose with a pliers (been there, done that!).
Thanks much!
Old 10-11-2011, 08:13 PM   #5
DIY staff
Most stores sell carpet protector strips---they look like Venetian blind slats---they work well but--you have tape and cardboard --so try using what you have on hand--
Old 10-12-2011, 04:23 PM   #6
Too Short? Cut it Again!
The carpet protection strips work alright but are expensive compared to tape. I have always used nice wide 1.5 to 2 inch masking tape. Tape along the baseboards with 3/8 inch on the baseboard. Then take a drywall knife and being careful not to tear the tape, press the excess down between the carpet and the baseboard. Paint. Make sure the paint is completely dry. Then pull the tape.
Old 10-16-2011, 05:57 AM   #7
m1951mm's Avatar
If the baseboard is put in 1/2" above the subfloor as it should be, you can just take strips of painters plastic, I like 1.5 mil thick, and use a putty knife (a six inch knife goes faster, you can use the plastic throw away mud knifes for this with the corners rounded off so it will not tear the plastic.) and slip the plastic under the baseboard. Paint to your hearts content but when you go to take the plastic out make sure to break the bond that may have been accumulated between the baseboard and the plastic. It is like sun burned skin, will peal, so run the knife along the base of the baseboard before pulling the plastic out.
Mickey
Fantasy Walls and Windows
www.picturetrail.com/mickey51
m1951mm is offline   Reply With Quote
Old 10-16-2011, 11:50 AM   #8
caroln242's Avatar
Also good idea!
Old 10-17-2011, 09:59 PM   #9
I bought a little tube of 'Paint Away' from Kleeneze. Its for emulsion or gloss and I've used it successfully on my jeans. Its a gel that lifts the paint off but you still have to pick at it a bit. I think its their own label so not sure if there is something in the shops thats similar....
Regards
Chantell Wilson
ChantellWilson is offline   Reply With Quote
Quick & Dirty Trim Salvage: Spackle to fill Old Chipped Paint? Lovegasoline Painting 13 09-01-2013 12:53 AM
Dark over light...Do I need tinted primer? melissaandkris Painting 17 09-09-2011 10:43 AM
latex paint on top of oil-based paint nancy-diy Painting 11 03-07-2010 03:02 AM
So many questions where to start?!?!(NEWBIE) painter84 Painting 5 09-15-2008 12:50 PM
Paint will not stick in Bathroom! SGTHetland Painting 9 08-17-2008 11:04 PM
