Can I Paint Flourescent Light Fixtures - Interior Decorating - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Interior Decorating
Old 12-25-2012, 12:34 AM   #1
can i paint flourescent light fixtures
Cant seem to find an answer to the above question. Anyone know?
sleepy23 is offline   Reply With Quote
Old 12-25-2012, 12:45 AM   #2
Rewards Points: 12,878
If your painting just the fixture and not the bulbs, then sure you can. Just tape off where the bulbs go in.
Old 12-25-2012, 07:35 PM   #3
Missouri Bound's Avatar
Of course you can. Why would you even ask?
Do you want it your way or the right way?
Old 12-26-2012, 05:10 PM   #4
Ambidextrous klutz
Leprechaun's Avatar
Rewards Points: 38
In a word, yes. As always, the key is in the prep. And with florescent fixtures, a high-quality finish will require spraying or hand-rubbing. (I don't expect the effort to hand-rub would make that an attractive choice.)
I recommend cleaning the fixture(s), then thoroughly roughing up the surface with fine steel wool; also it would be best to prime them with a primer compatible with your choice of finish paint.
At this point you would not be limited to metal paint; almost any high-quality washable paint would be fine.
HTH,
-Lep-
Leprechaun is offline   Reply With Quote
Repainting Room With Peeling Paint: Advice Needed Magnetic Painting 8 10-15-2012 06:19 PM
No power to light fixtures or switch in garage mrsirmrman Electrical 5 09-29-2010 04:36 PM
Drywalling around light fixtures davet Drywall & Plaster 1 06-28-2010 07:09 PM
2 Light Fixtures, one junction box NickSna Electrical 4 04-05-2009 04:02 PM
Flashing NoExperience Painting 13 09-04-2008 06:56 AM
