Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Interior Decorating
Old 04-29-2010, 02:49 PM   #1
Smile
Cafe Curtains in Finished Basement?
We are in the process of finishing the basement. Everything is looking great... except the windows. We struggle with the same problem as most people with finished basements, there are only small windows way up by the ceiling.
I want to keep all the light in there that I can, but these windows look silly in such an open space. My first thought was "cafe curtains", putting the bottom part just below the window, so it looks like a standard size window. I fear that cafe curtains anywhere other than a kitchen and maybe a bath would look strange.
What is your opinion of cafe curtains in a non-traditional setting? Do you have any other ideas you could share with me?
MEMama3 is offline   Reply With Quote
Old 04-30-2010, 09:39 AM   #2
yummy mummy's Avatar
Go against the norm......I love doing that. Heck, I put laminate on my walls in the basement, so that I could get a libraryish feel....... Take a look at my pics in the Project Showcase, and you can see what I did with my small window.
Cafe curtains I think would be fine. You can even bring them all the way down to the floor, and give the illusion that the window is bigger than it really is.
I have the same windows in my basement, and what I did was I put a sheer fabric panel, and I swagged it to one side and tied it, and I made them go right to the floor. In fact, I made them pool at the bottom.
You can even put panels on each side of the window, on the wall, giving illusion that the window is wider also. Just a thought.
Good luck!
yummy mummy is offline   Reply With Quote
Old 05-02-2010, 03:43 PM   #3
ahboo is offline   Reply With Quote
Old 05-15-2010, 05:28 PM   #4
WindowTreatment Installer
I think care curtains would be fine. Sounds like you want to make them an outside mount and mount them lower to give the appearance of a longer window. You could also use a top-down-botton-up shades such as a cellular shade or a woven wood (bamboo shade) for the same effect.
bobtheblindguy is offline   Reply With Quote
Tags
basement, curtains, windows
Thoughts and ideas basement finishing and HVAC creamaster HVAC 1 03-10-2010 08:46 PM
Below Grade Finished Basement Stays Around 55 Degrees diyourselfer Building & Construction 9 02-26-2009 08:11 AM
Basement finished with Low Ceilings and no permit missy22 Remodeling 11 01-30-2009 07:20 PM
Low ceiling finished basement pics SAGENT General Discussion 1 01-22-2009 12:46 PM
Basement mhughrob Remodeling 1 07-11-2008 08:11 PM
