Blank Canvass - Interior Decorating - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Interior Decorating
Old 07-14-2013, 07:55 PM   #1
n2omichael's Avatar
Rewards Points: 115
Blank canvass
Hey guys!
Not sure if this is the right forum, but, here goes:
I have recently moved my cottage onto a new foundation consisting of footings, a 4ft poured foundation and a 4 ft knee wall. I have a blank canvass to start with, what do you guys think would be better, dry wall the walls and ceiling and paint, OR, use vapour barrier, OSB and use toungue and groove pine or something similiar?i plan on spray foaming the the sills and using ROXUL in the floor/ceiling cavity, beyond that it's one big open room, any ideas or input is appreciated
If anyone has a website or program that lets you design or plan floorplans that would be a HUGE help too
Thanks!
n2omichael is offline   Reply With Quote
Old 07-18-2013, 08:02 AM   #2
Rewards Points: 274
I think your plan of spray foaming would be appropriate.
alexjoe is offline   Reply With Quote
Old 07-18-2013, 11:09 PM   #3
n2omichael's Avatar
Rewards Points: 115
Thanks! Appreciate that, heard good things about spray foam
Old 07-26-2013, 12:38 PM   #4
Too Short? Cut it Again!
Sweet Home 3D is open source floorplan software I like best. Lots of extra symbol sets if you want them. Very low learning curve. Accuracy is really up to you.
Others like the Google Sketch Up program.
Not sure I understand though. If you switched this thing to a new foundation, aren't you still stuck with the same bearing walls and so forth? How creative can you be with a floorplan? Some clues as to what you actually have and how big this one giant space is could be helpful. What framing is holding the roof on?
Old 07-26-2013, 12:48 PM   #5
n2omichael's Avatar
Rewards Points: 115
I have the same floor plan for the "main" floor, but, the cottage previously sat on footings, there was no lower level/basement, now it will be on a full 8 foot foundation, so, I basically have 4 walls and a centre beam with 3 jackposts running down the centre. Other than that it's empty and bare.
Was looking for input and/or software so I could mess around with my layout (bathroom, media room, closet, etc) so I could decide what direction to go with, and try some different options and layouts without having to draw everything out by hand, something I am not very good at.
Will check out those programs, Thanks!
Old 08-06-2013, 12:19 PM   #6
Home Designer can help with your floor plans, and more. Just posted a video of a walkthrough on Youtube. You can find it by putting in Home Designer Walkthrough under
Sisterearth is offline   Reply With Quote
Thermostat Screen is Blank sweaty HVAC 10 01-03-2013 02:10 PM
Thermostat Blank Screen jpeyster58 HVAC 1 09-22-2012 12:37 PM
Carrier 8000T Thermostat blank jeffetdiy HVAC 4 02-03-2011 10:11 PM
Thermostat blank - no heat/ac - fan works snosurfa7 HVAC 4 10-29-2010 12:42 PM
What's going on behind this blank plate? cbaileyau Electrical 11 12-19-2009 09:46 AM
