Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Interior Decorating
Old 08-21-2010, 09:26 AM   #1
bed with window behind it...
My bedroom is tiny and has a window right behind the bed, not centered. THe bed is in the only place it can be to have enough space for my husband and I to get in and out on either side. I just bought a bed that has no headboard, as you can see in the pic, but I want to do something fun with the wall behind it that will sort of serve as a decorative headboard. I was thinking of a wall of wallpaper but my husband hates wallpaper. Any ideas on how to do a decorative wall there or some type of headboard that won't block light?
vivenzio is offline   Reply With Quote
Old 08-21-2010, 04:20 PM   #2
the hard way: reframe the window and use something shorter and wider
the easy way: do a color scheme with a light tan - brown paint on the wall that window sets in.
racebum is offline   Reply With Quote
Old 08-22-2010, 04:27 PM   #3
WindowTreatment Installer
Something fun would be a window treatment that would give the illusion of a larger room. Take a look at this, a panel track blind. Mount it about 6 inches above the window frame and make it as wide as the ceiling. Comes in all sorts of materials. Good luck
bobtheblindguy is offline   Reply With Quote
Old 08-25-2010, 09:36 PM   #4
I guess this is a dump question as you have already mentioned in your first post about the position of the bed. But, can't you make it sideways as the slanted wall could be a nicer headboard? Don't answer if this question annoys you.
As for the window, I'm with racebum regarding the hard way. It's a good option.
MagicalHome is offline   Reply With Quote
Old 08-26-2010, 06:31 PM   #5
You could always go for a larger vinyl wall piece... like a flock of birds flying out of the window, or a big tree!! There are a ton on www.etsy.com (search "vinyl wall decal" and you'll hit the jackpot). Fairly inexpensive and non-permanent!!
aimeesrockworks is offline   Reply With Quote
Old 08-28-2010, 02:30 PM   #6
Something Fun in the bedroom got my attention .
disapponted in the rest. .
Go to www.fathead.com and get a big wall decal for on the wall.
Yeah I know that was no help. Lowes has bamboo blinds. I would get a 4' wide blind but instead of hanging it over the window I would mount it sideways on the wall. It would give a island hut look--serious! I will try to find pics ty pennington has done it on make overs looks good!
What have I done is offline   Reply With Quote
Old 08-28-2010, 02:49 PM   #7
KemoSabe
loneframer's Avatar
Keep in mind that there are codes that relate to the windows size and sill height for bedroom windows. (Egress) Please consider egress specifications if you decide to change the windows size or location.
loneframer is offline   Reply With Quote
Old 05-10-2011, 05:24 AM   #8
Hi, You can try Wall Decals. Made from vinyl, it is a fun and affordable way to transform any room. They can also be removed when you want a change without damaging the walls. Try http://crazysexycool.co.za/ they are from South Africa but will ship internationally.
B3happy is offline   Reply With Quote
Old 05-10-2011, 09:24 AM   #9
Find a fabric you love for the window and mimic it on the wall.
klmeenan is offline   Reply With Quote
Defog window recap greenmax General Discussion 4 05-07-2010 06:00 PM
How to 'finish' outside of replacement window? KatieAK Building & Construction 9 04-02-2010 07:37 AM
help need to know how to replace windows wrapped in drywall caide3 Carpentry 4 03-02-2010 01:41 PM
Moisture on windows baum Building & Construction 56 12-22-2009 06:39 PM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 06:11 PM
