Baseboards On Plaster Walls... - Interior Decorating - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Interior Decorating
Old 02-21-2013, 08:42 PM   #1
Rewards Points: 97
baseboards on plaster walls...
I have old plaster walls. How can i attach the baseboards to it? I am afraid if i try to shoot a nail through the baseboard it will break the plaster. What have you guys done?
bcbud3 is offline   Reply With Quote
Old 02-21-2013, 08:48 PM   #2
Rewards Points: 14,000
Unless your trying to use spikes a finish nails not going to hurt it unless it's in really bad shape.
See if you can located the studs by looking along the bottom plate area.
A stud finders not going to work on plaster because of the lath.
Old 02-22-2013, 03:31 AM   #3
paper hanger and painter
chrisn's Avatar
Rewards Points: 496
a good stud finder WILL work
chrisn is online now   Reply With Quote
Old 02-23-2013, 10:38 AM   #4
Rewards Points: 97
My wall doesn't have wood lathe it has 1/4 gypsum sheets...stud finder should work.
Best picture hanging system that won't damage plaster walls? ohman Drywall & Plaster 11 10-09-2012 01:00 PM
Peeling Paper off of Plaster Walls train_rider Drywall & Plaster 4 03-25-2012 07:50 AM
Dry wall replacement of plaster walls nlkoebel Drywall & Plaster 2 12-21-2011 12:37 PM
Finishing Basement Walls, Inside Perimeter Drains, and Moisture, Oh My BSponz1 Building & Construction 1 02-08-2011 01:20 PM
Remodeling a half bath with plaster walls rh8868 Kitchen & Bath Remodeling 26 01-28-2010 12:14 AM
