Attaching Shop Finished MDF To Drywall - Interior Decorating - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Interior Decorating
Old 11-08-2010, 03:37 PM   #1
Attaching Shop Finished MDF to drywall
I need to flush mount a number of pieces of shop-painted MDF to drywall. The largest piece is 7'6" x 2'2" wide. I can not use a nailer because the MDF is professionally finished. What is the best way to flush mount this to drywall - construction adhesive??
Greg Stevens is offline   Reply With Quote
Old 11-11-2010, 04:59 PM   #2
Fixer-'til-broker
DIYtestdummy's Avatar
Rewards Points: 262
I'm not sure what you are going for. Got pics? Why can't you use a finish nailer and just touch up the holes? How thick is the MDF? If you can use a pin nailer you won't even notice.
Tacks on the other side? (I can't remember the name for these, but I've used them for acoustic tiles)
Adhesive would tear the drywall if you ever had to remove them, but it should work if you can hold them there for a while. Contact cement would probably be a better choice, but I'd still use a nailer.
"Aw! Why does everything that only happens to stupid people happens to me?" - Homer J. Simpson
DIYtestdummy is offline   Reply With Quote
Moving ductwork to accomodate finished basement Badfish740 HVAC 1 01-13-2010 03:11 PM
Ecorock (new green drywall product) Sir MixAlot Drywall & Plaster 0 06-20-2009 08:40 AM
Drywall over plaster? Rob1980 Drywall & Plaster 10 04-11-2009 05:05 PM
Good ways to run pegboard up to drywall? upthemaiden Drywall & Plaster 1 03-09-2009 01:12 PM
Attaching kitchen cabinets directly to studs with no drywall between nrabate Carpentry 7 08-28-2007 09:01 AM
