Anyone Ever Paint A Fridge? - Interior Decorating - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Interior Decorating
Old 02-06-2009, 09:55 PM   #1
Anyone ever paint a fridge?
Ok, I was given a house. Included was a very horrible two tone brown 70's model fridge, kind of like the one in "That 70's show." It is a General Electric, model year 1977.
Anyway, my question is this: I have painted more than one vehicle in my life, and I'm wondering if it would be the same concept? Prep, mask, primer, paint, clear, wet-sand for high gloss? The reason I am asking is because the fridge works great, but the kitchen is done in silver with black trim, so it clashes terribly. I'd really rather afford to spend money elsewhere, if I can, since the fridge works great. I used high heat paint to spray the stove, should I use the same thing on the fridge?
Any pointers would be greatly appreciated. Included is a sample pic of the color I'm dealing with. It's not my actual fridge, just a random photo I googled.
BioHazard is offline   Reply With Quote
Old 02-06-2009, 11:04 PM   #2
Since you've painted cars, you understand all the prep work involved for good end results. What can it hurt to try? You screw it up, either try again or then make the decision to junk it and buy a new one.
Jeeper1970 is offline   Reply With Quote
Old 02-06-2009, 11:55 PM   #3
Rewards Points: 2,906
I'm sure that if you paint your fridge just like you'd paint a car, you'll have a fine looking fridge.
Maybe a tangerine metallic would be nice.
Bashing my head against the walls in some of the internet's finest chat rooms.
Nestor_Kelebay is offline   Reply With Quote
Old 02-07-2009, 12:50 AM   #4
Tom Struble's Avatar
Rewards Points: 2,002
a fridge that old your probably better off saving the time and money you put into painting and get a new one they are much more efficient now it would probably save you money just in energy cost
Tom Struble is offline   Reply With Quote
Old 02-07-2009, 11:35 AM   #5
I painted one black - turned out OK
But if it is that old its going to use a lot of power
We went from a 18 cu ft old fridge to a new 26 cu ft fdridge & are using less power with the new one
Old 02-07-2009, 11:58 AM   #6
Remodeling Contractor
method may be similar to car painting by paint is not. They make an appliance paint for this purpose. Do not attempt to use the brush on for anything more than minor chip fixes or the can spray on for larger fixes. Use an HVLP sprayer. Bring the unit outside or use adequate ventilation and protection. This is an acrylic paint and the fumes are harmful to pets and humans. You should be able to find at any hardware or paint store or on line at sites like www.onecoat.com and www.appliance-warehouse.com.
Old 02-07-2009, 08:18 PM   #7
Tired & Dirty
Rewards Points: 83
had a body shop paint one for me and it looked great, course the compresser died 6 months after it was painted, so like the others said risky, at best. it cost me 250.00 for the paint job .
evapman is offline   Reply With Quote
Old 02-07-2009, 08:26 PM   #8
Rewards Points: 392
Automotive paints work fine for this, just use the same process: clean, prep, scuff and shoot. If you use the right undercoats, automotive finishes work great on wood too.
rustyjames is offline   Reply With Quote
Old 02-07-2009, 10:58 PM   #9
Well, I have painted a few cars in my garage, and currently have approximately half a gallon of unreduced Mitsubishi Kalapana Black, which was used on 95-99 Eclipses. I still have my "booth" set up from the last car I painted. I think I am going to scuff and prep it, and then I'll prime and paint it this week. Since I already have all of the supplies needed, I'm going to attempt it, and see how it looks in Black and Chrome. It can't hurt to try, I guess. I'll do a How-To article when I get it done, and hopefully someone else can benefit from my experimentation.
**EDIT**
I was also wrong about something, I posted earlier that it was a 1977 model. It is actually a 1987 model.
Old 02-13-2009, 05:01 AM   #10
You being a car painter should know this - that when your wife decides to clean it with oven cleaner it will turn into a mess of weird swirls. Also a 87' vintage probably does use twice the power of a new one especially being a side by side. Saving $10 a month will take 10 years to pay back on a $600 high efficiency over/under model.
hychesee is offline   Reply With Quote
Old 02-14-2009, 09:19 AM   #11
Hvacr Professional
Hvac pro's Avatar
just dont paint the condenser coil ....may look like a radiator or similar.
Hvac pro is offline   Reply With Quote
Old 02-15-2009, 06:29 AM   #12
SNC
HA HA I thought this thread was a prank, throw it out and get a new one.
You got a free house what more do you want ???
SNC is offline   Reply With Quote
Old 02-17-2009, 02:25 PM   #13
Nah, I'm just trying to save a few dollars that would benefit other repairs on the house. It has a lot of things that need repairing.
Old 02-18-2009, 09:06 AM   #14
Mold!! Let's kill it!
Rewards Points: 2,012
Long ago, I painted one with automotive enamel. Worked fine. Heck, one of auto finish companies even had a color called "appliance white".
Old 02-19-2009, 04:45 PM   #15
Rewards Points: 184
Would electrostatic paint work good for this?
abefroman is offline   Reply With Quote
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 08:46 PM
Dark over light...Do I need tinted primer? melissaandkris Painting 17 09-09-2011 11:43 AM
semi gloss enamel vs eggshell enamel NoExperience Painting 18 03-05-2009 05:57 AM
Flashing NoExperience Painting 13 09-04-2008 06:56 AM
Semi gloss on Semi gloss mattpricemn Painting 6 08-25-2008 08:18 PM
