Advice For Main Bath Mirror Wall. - Interior Decorating - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Interior Decorating
Old 03-23-2013, 07:54 AM   #1
Rewards Points: 212
Advice for Main bath mirror wall.
Got this,
But was going for this,
I'm looking for minimal work in the bathroom. The top row of vinyl tiles are mismatched replacements which may get painted to match the other black ones. I would like to gut the bathroom and start over but short on money and time/ideas.
There used to be a different mirror. I can move this one up and add the trim to achieve more of the late thirty's look.
The electrical available is on either sides of the mirror (you can see patches I threw on before I learned this is against code). It would be easiest to use these but not sure what kind of fixture would aesthetically work- seems most lights are above however this might aid in the retro look.
The only problem with the wires above the mirror is they are hot all the time and would have to be switched at the light.
I might have to go to electrical to ask how to reconfigure but would like to live with it to avoid the changes.
In conclusion the main issue is what type of side lights to use for this arrangement. Btw, it's the only bath for now with family of four, including a 9 and 10 year old girl and boy.
Was also considering Ralph Lauren suede on walls but have no clue what color to use with the tile.
Thank you for reading this. I appreciate any direction you could give on this and will try to keep up with further discussion.
Squeakyhinge is offline   Reply With Quote
Old 03-23-2013, 07:56 AM   #2
Rewards Points: 212
Please note the captions for the pictures are reversed what I wanted. The wall photo is mine. The other is an idea.
Old 03-23-2013, 11:17 AM   #3
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,086
Do you want just a mirror, or do you need a medicine cabinet behind it?
If you want a medicine cabinet that trim will be a problem.
If so, you might check out this thread.
Custom with Cabinet help
Edited to add: If you go to google images (or bing) "vintage bathroom lighting fixtures" you will see there are a lot of options for lighting that would work at that height. Finding them at a reasonable price may be a challenge.
Old 03-23-2013, 01:20 PM   #4
Rewards Points: 212
Thanks for the reply.
Vintage is the key word for google, thanks!
I could go either way with a medicine cabinet. We could always use more space, whether from vanity under sink, over toilet, or hidden behind the door, or all three. Right now is pedestal sink and showerless tub.
I was thinking the mirror will probably need remounted. It is a cabinet. The molding won't fit otherwise.
Old 03-23-2013, 03:39 PM   #5
Rewards Points: 212
It's already a mirror and cabinet. Could also use one above toilet, behind door, and a sink vanity but don't want it to look to utilitarian. I will probably have to move the mirror/cabinet up to give room for the "sill" and "skirt".
Thanks for the "vintage" word; great for google search.
I'm pretty flexible with the mirror; I'm due for an update anyway. I just want storage space somewhere unless it interferes with the design concept.
Old 02-20-2014, 11:02 AM   #6
Rewards Points: 808
Check out restoration or antique stores, thrift shops, flea markets for porcelin bath sconces with the milkglass globes. Having 2 lights on the side of the mirror is far superior to a fixture mounted above, just ask any guy who shaves his neck.
IslandGuy is offline   Reply With Quote
Advice on Replacing Rusted Bath Undermount Style Sink mdonovan Plumbing 12 11-09-2013 02:36 PM
ADVICE appreciated on Bath Remodel Sunsetcliffs98 Kitchen & Bath Remodeling 9 02-01-2010 05:22 PM
Need Advice - Removing Bath Wall Tile Soxckersfc2002 Kitchen & Bath Remodeling 6 02-01-2010 10:49 AM
Shattered glass down my bath drain! gudgebum Plumbing 3 01-08-2010 12:52 PM
1/2 Bath Remodel - Need Advice allen1466 Remodeling 5 01-22-2007 11:44 AM
